Actions
In the Actions tab, configure the actions which users assigned to this role can perform within EMC.
Figure 5-3 Roles Actions Tab
This figure shows the Roles module and its Actions tab.
Similar to the options on the EMC Modules tab, selecting the All Actions check box grants users associated with this role permission to perform all actions. Oracle recommends that administrator-type roles have this option checked so that administrators can always perform all types of actions, including future actions that are not currently in the system.
Table 5-5 EMC Module Actions
Action Description
All Actions
Grants the ability to perform all actions and prevents enabling or disabling individual actions.
Key Manager
Message Stats
Fix Carried Over Totals
Tasks
Distribute
Remote Distribute Out
Remote Distribute In
Create CC Batch
Deprecated
Edit CC Batch
Deprecated
Create CC Batch
Deprecated
Transfer CC Batch
Deprecated
EMC Text Translations
Workstation Text Translations
Workstation Status / Control
ServiceHost Status / Control
Wireless Monitor
Device Information
View Employee IDs
View Deleted Employees
Permanently Delete Employees
Can Change Others' Passwords, Email Addresses and Security Questions
Enterprise Audit Trail User
Select to allow users associated with the Enterprise role to access the Enterprise Audit Trail and Property Audit Trail.
Access Property Audit Trail
Select to allow users associated with an employee role to access the Property Audit Trail.
Purge Audit Trail
Select to allow users associated with the Enterprise role to manually purge Audit Trail records.
Clear Totals
Export Configuration
Import Configuration
Enterprise Autosequence User
Deprecated
Property Autosequence User
Deprecated
Run Autosequences in Priv Group 1
Deprecated
Run Autosequences in Priv Group 2
Deprecated
Run Autosequences in Priv Group 3
Deprecated
Run Autosequences in Priv Group 4
Deprecated
Run Autosequences in Priv Group 5
Deprecated
Run Autosequences in Priv Group 6
Deprecated
Run Autosequences in Priv Group 7
Deprecated
Run Autosequences in Priv Group 8
Deprecated
