Configuring Event Privileges and Permissions
You can assign event privileges to employees.
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type, and click the EMC Modules tab.
- For each of the following event-related items listed in
the File column, select the appropriate employee privileges (View, Edit, Add, and Delete):
Event Types: This file controls the ability to view, change, create, and delete event types and sub types.
Event Areas: This file controls the ability to view, change, create, and delete event areas.
Event Definitions: This file controls the ability to view, change, create, and delete events.
Creating Roles contains more information about setting privileges. -
- To set field level permissions, click the Fields tab.
- Select Event Definitions from the EMC Modules list.
- For Areas and Cancel Event, select the appropriate permissions from the Access drop-down list.
- To set event check privileges, click the Operations tab, and then click the Transactions subtab.
- Select the appropriate options for the privileges. The
following table summarizes the check privileges associated with event
functionality and the recommended roles to have the privilege set.
Table 38-1 Event Check Privileges
Option Number Privilege Name Allow the Employee to Authorize or Perform ... Recommended Roles 270
Authorize/Perform association of a new check to an ended event
Creating a new check and linking it to a closed or ended event
Manager
271
Authorize/Perform override of the "Event association to a Check is mandatory" option (Control Parameters)
Beginning a check without linking it to an event
Manager
- Click the Miscellaneous subtab.
following table summarizes the workstation privileges associated with
event functionality and the recommended roles to have the privilege
set.
Table 38-2 Event Privileges
Option Number Privilege Name Allow the Employee to Authorize or Perform ... Recommended Roles 272
Authorize/Perform Start an Event
Starting an event
Manager
273
Authorize/Perform End an Event
Ending an event
Manager
276
Authorize/Perform Select an Event
Selecting an active event as the workstation operator’s default event
Manager
277
Allow selection of ‘No Default Area Selected’ when assigning default event
Selecting a default event without selecting a default area.
Manager
- Click Save.
