Configuring System Management - Common Profile Switches
This section lists the configurable sections for Common Profile Switches.
Select System Configuration and then System Management to view the Common Profile Configuration screen.
Tip:
The Common Profile folder appears in a tree-view on the left panel. The components are categorized as folders. Each folder contains all the field labels associated with that section.Note:
If any change is made in the System Management (Common Profile Switches) screen, theArgusvr2.exe
and
Argusvr2a.exe
should be killed from each Web Server and the
IIS on Oracle Argus Web / Report Servers must be reset, in order to reflect the
changes made in the application.
The following table provides the list of configurable sections associated with Common Profile Switches.
Section | Sub Section | Description |
Advanced Conditions |
The Advanced Conditions configuration screen enables you to specify the number of rows to be displayed on the Advanced Condition search screen. |
Argus Dossier |
Report Configuration |
The Oracle Argus Dossier screen enables you to modify the customizable fields of Argus Dossier. |
Argus Insight |
If Oracle Argus Enterprise products are enabled, the Oracle Argus Insight URL can be provided here. |
Argus J |
E2B Reporting Device Report Responsible Officer |
The Argus J Configuration screen enables you to modify the customizable fields on the Argus J form. |
Argus Mart |
If Argus Enterprise products are enabled, Oracle Argus Mart related settings can be configured here. |
Background Services |
This screen enables you to configure the Common Profile Switches that affect the behavior of Background Services. |
Case Form Configuration |
This screen enables you to configure Common Profile Switches that affect the behavior of the Oracle Argus application |
Case Processing |
Assessments Always Show Literature Data Auto Archiving Case Numbering Dictionary Browser Enable Local Unlocking Group Data Access Lot Number Processing Performance |
This section enables you to configure the case processing fields and items. |
Database |
The database related parameters can be maintained here. Calculation functions for Case Seriousness, Listedness and Causality calculation. |
Document Management |
This screen enables you to configure the Documentum fields and items for Documentum. |
Help |
Centralized Online Help URL. |
Local Labeling |
LAM |
The Local Labeling Configuration screen enables you to modify the options available through local labeling. |
Network Settings |
The Network Settings screen enables you to modify the settings on the Argus Safety Load Balancer Server and Proxy. |
Reporting |
BIP Reporting E2B eMDR eVAERS Expedited Expedited - BfArM Expedited - Canada Expedited - CIOMS Expedited - MedWatch MedWatch Configuration Periodic Scheduling |
The Reporting Configuration screen enables you to modify the options available for reporting. |
Security |
Cryptography LDAP |
The Security Configuration screen enables you to modify the options available for security. |
Session Timeout |
Session expiration time in minutes |
The maximum idle time allowed for a user's session. Valid range for this value is 5-1440. Default value is 30 min. Note that long running processes like CDA are controlled through the table CMN_URL_ACCESS_GLOBAL where user can specify a timeout value local to that process. Further, the user would need to set the process as IS_LONG_RUNNING = 1. By default, the following are categorized as long running: '/REPORTS/CIOMSII/CIOMS2_SAVING.ASP' '/AUDITLOG/AUDITLOGLIST.ASP'; '/REPORTS/CDA/CDAGENERATE.ASP', |
Single Sign-On |
The Single Sign-On screen enables you to modify the options available for Single Sign-On such as enabling or disabling it, its HTTP Header, Logout URL, and using Oracle Access Server SDK for LDAP Validation. Note that in a SSO configured environment, for the SSO to take effect, the session timeout value should be set to maximum value. |
User Interface |
The User Interface screen enables you to modify the options available for User Interface. |
Workflow |
The Workflow Items screen enables you to modify the options available for Workflow Items. |
For more information, see:
- Configuring Advanced Conditions
- Configuring Background Services
- Configuring Case Form (System Management)
- SMTP Configuration
- Configuring Case Processing
- Configuring Database
- Configuring Assessments
- Configuring Auto Archiving
- Configuring Case Numbering
- Configuring Lot Number
- Configuring the Dictionary Browser
- Configuring Group Data Access
- Configuring WHO Drug
- Configuring Performance
- Configuring Documentum
- Local Labeling
- Network Settings
- User Interface
- Configuring Reporting
- Configuring Security
- Configuring Single Sign-On
- Error Messages
- Configuring SMTP
- Configuring Workflow Items
Parent topic: System Configuration
