Data Installer modes
The Data Installer has the following modes:
- Download—Used to export data from the Central Coding application.
When you export data using the Download mode, an export configuration XML file is created. You can use this file with the Data Installer to import or update data in the Central Coding application.
- Setup—Used to import data into the Central Coding application.
To import data in the Central Coding application, you can use the export configuration XML file that is created when you run the Data Installer in Download mode, a manually created XML configuration file, or the sample XML configuration file called CentralCodingConfigMaster.xml, which you can edit as needed.
- Update—Used to update existing data in the Central Coding application.
To update data in the Central Coding application, you can use the export configuration XML file that is created when you run the Data Installer in Download mode, a manually created XML configuration file, or the sample XML configuration file called CentralCodingConfigMaster.xml, which you can edit as needed.
Note: The sample XML file is installed in the same location as the Data Installer.
