Overview of the steps to set up the dictionary database
Note: Setting up the dictionary database is the same for both standard and custom dictionaries.
Steps to set up the dictionary database
Step |
Task |
Description |
1 |
Use to create a repository in the database to hold the dictionaries associated with a connection. Although you can create multiple repositories, only one repository can be connected at a time. |
2 |
Use to create a connection to the database. Connections are created within repositories. Although you can create multiple connections, only one connection can be active at a time. |
3 |
Use to connect to an existing database connection. |
4 |
Use to view information about the dictionary types that are available for a connection. |
5 |
Use to import the dictionary type XML file for a dictionary. |
