Reviving a dictionary schema
Reviving a dictionary schema recreates the schema of a previously removed dictionary. For more information, see Removing a dictionary schema. After reviving a dictionary schema, you can load data into the dictionary.
- Select Start > Apps > Dictionary Loader.
The Dictionary Loader dialog box appears.
- Select a connection and connect to the database.
For more information, see Connecting to the database.
- Select the Dictionaries node for the active connection.
- Select a dictionary with a status of REMOVED.
- Select Dictionary > Revive.
The New Dictionary dialog box appears. The information in most fields is read-only because it already exists in the database.
- Enter the following information.
- Schema Password—The password for this dictionary schema.
- Confirm Schema Password—The password for this dictionary schema.
- Tablespace—The name of the tablespace that was created for the dictionaries.
- Click OK.
- If prompted, enter the user name and password for the dictionary database administrator, and click OK.
