Using the Dictionary Loader to convert the WHO-DD dictionary to C format
- Select Start > Apps > Dictionary Loader.
The Dictionary Loader dialog box appears.
- Select a connection and connect to the database.
For more information, see Connecting to the database.
- In the Data Connections tree in the left pane, select the Dictionaries node for the active connection.
Information about the dictionaries for this connection appears in the top pane.
- Select the WHO-DD B format dictionary.
- Select Dictionary > Convert WHODD B to C.
The Locate File dialog box appears.
- Click Browse and locate the folder that contains WHO-DD B format dictionary files.
- Select the directory and click Open.
The full path to the files appears in the Location field.
