Checklist: Set up InForm studies for use with the Central Coding application
Steps to set up InForm studies for use with the Central Coding application
Step |
Task |
Description |
1 |
In the InForm application, specify a valid InForm user whose credentials can be used by the Central Coding application to access the InForm application. Required only if you are using user name/password authentication for communication with the InForm Adapter web services. |
Enter the InForm authentication user name and password in the Central Coding application:
2 |
In the Central Designer application, create a rule in the InForm application to clear the coding targets (optional). |
If the following key items are changed in the InForm application after a verbatim is coded, they will not be updated in the Central Coding application. To get the key items to be updated, you must create a rule in the InForm application to clear the coding targets.
Note: The key items are updated in the Central Coding application if the verbatim is not coded in the InForm application. |
3 |
In the Central Designer application, create the coding maps. |
Specify mapping definitions for controls that hold verbatim text and controls that hold the coded values assigned by the InForm application. For more information, see the Central Designer documentation. Note: Oracle recommends that you do not modify coding maps after coding begins for the study. Doing so can slow the coding process. |
