Checklist: Setup tasks for integrating the Central Coding and InForm applications
Steps to set up integration with the InForm application
Step |
Task |
For details, see... |
1 |
Install the Central Designer software. |
Central Designer Installation Guide. |
2 |
Install the InForm software on a different machine than the Central Coding application server. |
InForm Installation Guide. Note: Set up the InForm Adapter to accept data securely. |
3 |
On the InForm application server, install the InForm Adapter software with the Administration, Coding, and Discrepancy Enhanced interfaces. |
InForm Adapter Installation Guide. Note: Set up the InForm Adapter to accept data securely. |
4 |
On the InForm application server, register studies with InForm Adapter. |
InForm Adapter Installation Guide. |
5 |
Using the Central Designer and InForm applications, set up one or more InForm studies. |
Specify mappings and add InForm users for use with the Central Coding application. For integration with the InForm 5.0 release or later, see the InForm Study and Reporting Setup Guide. For integration with releases prior to the InForm 5.0 release, see the InForm Installation and Configuration guide. For more information, see Checklist: Set up InForm studies for use with the Central Coding application and About mapping data for coding with the Central Coding application. |
