Checklist—Planning the client installations
Use the following checklist to help plan the installations of the client applications.
The Central Designer and Central Designer Administrator applications are ClickOnce applications. You start a ClickOnce application by clicking a link from an Internet Explorer or Edge window.
When you click a link for either application, the Central Designer server checks whether the release that is installed on the server matches the files that are cached on your computer:
- If the server has been newly installed or has been upgraded after your last logon, the files that are necessary to run the application are cached on your computer, and then are used to open the application.
- If the server has not been updated since your last logon, the cached files on your computer are used to open the application.
þ
Task
Information
q
Make sure all system requirements, including .NET Framework requirements, have been met for the client computers.
- Central Designer System requirements.
- Verifying that the correct version of Microsoft .NET Framework is installed.
- Enabling TLS 1.2 for .NET Framework on client computers.
q
(Optional; this step is informational only.) Check whether the Microsoft Internet Explorer browser uses a proxy server to connect to the Internet. The Central Designer software uses the same proxy server.
q
For clients using Microsoft Edge browser version 79 or later, enable ClickOnce support.
Enabling ClickOnce support for Microsoft Edge version 79 or later
q
Make sure the clocks on the application server computer, database server computer, and client computers are synchronized.
q
Start the client applications.
