Design tab of the Item Editor—Option descriptions
Compound or blood pressure item options
Option |
Description |
Compound Properties section |
Default question |
Default question for the item. This question appears on the form if no customized label or translation is defined for the item. The question can have 0-1000 characters. Certain words may be reserved for this field. |
Title |
Title of the item. The title can have 1-63 characters. |
Child Items section |
List the items that make up the compound item. For a blood pressure item, the predefined child items Systolic Variable and Diastolic Variable appear in this list. |
Type |
Item type. For a blood pressure item, the item type of the two child items is Integer. |
Title |
Title of the child item. The title can have 1-63 characters. |
RefName |
RefName of the child item. |
Question |
Caption that appears with the child item on the form. |
Languages section |
Languages section |
Translate item questions. This section is active if:
Language |
Language in which the question appears. |
Question |
Text of the question in the specified language. The question can have 0-1000 characters. |
Short Question |
Text of a short version of the item question. In the InForm application, the short question appears as a column heading in a repeating form, an itemset, and in reports generated by the Reporting and Analysis application. The short question can have 0-255 characters. Certain words may be reserved for this field. |
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
Date time item options
Option |
Description |
Date Time Properties section |
Default question |
Title |
Title of the item. The title can have 1-63 characters. The title can have 1-63 characters. |
Year Month Day Hour Minute Second |
When selected, this part of the date time item (Year, Month, Day, Hour, Minute, or Second) can be made visible on the form if it is marked as visible in the Layout tab.
Languages section |
Languages section |
Language |
Question |
Text of the question in the specified language. The question can have 0-1000 characters. Certain words may be reserved for this field. |
Short Question |
Notes:
- To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
- The Required and Allow unknown fields are not available until you select the corresponding Allow fields.
Float item options
Option |
Description |
Float Properties section |
Default question |
Title |
Base Unit |
The unit for which a measurement is stored in the repository. |
Conversion Units |
One or more optional units in which a user can enter a measurement. A conversion unit value is converted to the base unit when stored in the study database. |
Length |
Maximum length of the data that a user can enter into the item, including the values before and after the decimal point. Note: When a float item is deployed to an InForm study, the decimal point counts in the length, and you must account for the decimal point when designing the float item. For example, in the InForm application, the largest number that can be entered in a field that has a length of 4 and a precision of 1 is 99.9. |
Precision |
Number of required characters following the decimal point. |
Codelist Settings |
Codelist section |
Codelist section |
Select or define a codelist for the item. A codelist consists of a group of codelist items, each containing a code and a label. |
Codelist |
List of existing codelists or the name of a new codelist that you type. |
New |
Create a codelist in the repository, using the name entered in the Codelist field. |
Code |
Value stored in the repository for the codelist item. The value can have 1-2000 characters. |
Label |
Default label that appears on the form for the codelist item. The label can have 1-255 characters. |
Languages section |
Languages section |
Language |
Question |
Short Question |
Integer or yes no item options
Option |
Description |
Integer Properties section |
Default question |
Title |
Base Unit |
Conversion Units |
Length |
Maximum length of the data that a user can enter into the item, including the values before and after the decimal point. |
Signed Value |
Reserved for future use. |
Codelist settings |
Codelist section |
Codelist section |
Select or define a codelist for the item. A codelist consists of a group of codelist items, each containing a code and a label. Note: A yes no item includes a predefined codelist named YesNo Codelist. This codelist has the values 0 (No) and 1 (Yes). |
Codelist |
New |
Code |
Label |
Languages section |
Languages section |
Language |
Question |
Short Question |
Text item options
Option |
Description |
Text Properties |
Specify text item properties. |
Default question |
Title |
Length |
Codelist Settings |
Codelist section |
Codelist |
New |
Code |
Label |
Languages section |
Language |
Question |
Short Question |
Default maximum input field lengths
When you create an item, you specify the length of the input field. The Central Designer application supports the following maximum field lengths as a default.
Type of input field |
Maximum length |
Text item |
2000 |
Integer item |
10 |
Float item |
18 |
Float precision |
10 |
