Design tab of the Form Editor or Section Editor—Option descriptions
Option |
Description |
Repeating |
Indicates that the form or section is repeating. Multiple instances of the same set of data appear in the form or section. |
Common (forms only) |
Indicates that the form is common. The same data is visible in all study events that contain the form. |
Fixed (sections only) |
Indicates that the section is a fixed repeating section containing static text that repeats for each instance of the item. |
Keys (toolbar button and icon for repeating forms and sections only) |
Fields |
Codelist |
Applies to text, float, and integer items only. Drop-down list with available codelists for the item. Available codelists are all of the codelists in the study or library with the same type as the item. |
Codelist Subset |
Select a subset of codelist items to add to the codelist. |
Conditional On |
Title of the item on which the current item is conditional. The drop-down list in this column contains items that contain a codelist. If the current item is conditional on one of the items in this column, the current item provides additional data about one of the options in the codelist. |
Conditional Value |
Code and label of the codelist item on which the current item is conditional. |
Data Label |
Description |
Description of the item. The description can have 0-255 characters. |
Display Override |
Item Properties |
Contains an Edit link, which you can click to open the Item Properties dialog box. If you navigate to the field using the Tab button, you can open the dialog box by pressing the spacebar. |
Item Required |
Indicates that the item is required. |
Key |
For key items, displays icons and numbers that indicate:
In the InForm application, key items are used to make it easier to navigate among the instances of a repeating form and to enforce data uniqueness in specific items. |
Length |
Applies to text, float, and integer items only. Length of the item. Allowed values:
Locked |
Indicates that the item is locked. |
MaxProperty |
If a MaxValue is specified for the item, indicates whether the value can be less than or less than or equal to the MaxValue. |
MaxValue |
Maximum value that the InForm application will allow to be typed for the item. |
MinProperty |
If a MinValue is specified for the item, indicates whether the value can be greater than or greater than or equal to the MinValue. |
MinValue |
Minimum value that the InForm application will allow to be typed for the item. |
Modified |
Indicates that the item has been modified and has not yet been saved. |
New |
Indicates that the item is new and has not yet been saved. |
Protected |
Indicates that the item is protected. |
Question |
Default question for the item. This question appears on the form if no customized label or translation is defined for the item. The question can have 0-1000 characters. Certain words may be reserved for this field. |
RefName |
RefName of the item. |
Revision |
Revision number of the study object. |
SDV Critical |
Indicates that the study object is considered critical for source verification. If you select SDV Critical, SDV Required becomes selected as well. |
SDV Required |
Indicates that the study object must be source verified in the InForm application. |
ShortQuestion |
Text of a short version of the item question. In the InForm application, the short question appears as a column heading in a repeating form, an itemset, and in reports generated by the Reporting and Analysis application. The short question can have 0-255 characters. Certain words may be reserved for this field. |
Special Fields |
Type of special InForm field, or None, indicating that the item is not a special InForm field. Available special fields, along with the forms in which they appear, are:
Title |
Title of the item. The title can have 1-63 characters. |
Type |
Item type; one of the following, or a custom item type defined in a library to which the study has access:
Version |
Version number of the study object. The version number is incremented only when a user explicitly updates it. |
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
