Create a custom Clintrial context panel
- Create a data set for the context panel.
- Create a data series for each context item.
- On the Properties tab, set the values of custom properties for the data set and each data series, and press Enter.
Tip: If you don't see the Properties tab, at the top left of the page, select View, and make sure Properties is selected. - Optionally, map items to the data series.
If you do not map specific items to a data series, the values of the key items are derived from the control path of each InForm transaction as it is processed.
Note: The validation process checks the design of a custom context panel for compliance with Clintrial design rules. However, the Central Designer user interface does not enforce similar checking. Therefore, make sure that your definition of a custom Clintrial context panel does not violate Clintrial design considerations.
