Previous Topic
Next Topic
Book Contents
How are task statuses used?
Task assigned to you appear on your Home Page. All tasks appear on the Tasks tab.
Note: If a task is overdue, the status displayed in the status field is Overdue—[Current status], such as Overdue—Accepted.
Description of the workflow for tasks
Procedure
Task status
Description
Creating a task
Open
When you create a task, you assign it to one or more individuals or teams.
Accepting a task
Accepted
When you accept a task, you take responsibility for completing the task. Only one person can accept a task, and you can only accept tasks that are assigned to you.
After you accept a task, you can:
  • Mark it as Complete after you finish all required work.
  • Unaccept it if you will no longer work on the task.
Unaccepting a task
Open
You can unaccept a task that you have accepted but will no longer work on. An unaccepted task is assigned to the team to whom it was originally assigned. If no default team was selected, you are prompted to assign the task to a team or individual.
Completing a task
Completed
You can mark as Complete only those tasks that you have accepted. A completed task is assigned to the task creator.
The task creator can do the following to a completed task:
  • Close it if work is complete.
  • Reopen it if work is not complete.
Closing a task
Closed
You can close completed tasks that you created. You close a task after you verify that all work has been completed. A closed task is assigned to the task creator.
Reopening a task
Open
Two people can reopen a task, the person who created it and the person who completed it. A reopened task is assigned to the individual or team to whom it was assigned by default. If no default team was selected, you are prompted to assign the task to a team or individual.
Send Feedback
