Running the DetectStudiesWithUnitsWithSpaces.sql script
A SQL script called DetectStudiesWithUnitsWithSpaces.sql generates a report that identifies the unit names with spaces and the study projects that contain unit names with spaces. Oracle recommends that you run this script because a validation check produces an error if a unit name contains a space.
Run the script before upgrading the application server. If the script finds units with spaces and study projects that use the units, perform the following steps:
- In any affected study, run validation to determine the items that refer to the units with spaces in their names.
- Modify the units file to remove the spaces from the unit names that appear in the output file.
- Using Control Panel > Administrative Tools > Services, restart the Job Scheduler service (Oracle Central Designer Job Scheduler).
- Restart the client applications.
- In any affected study, modify the items to use the unit names that do not contain spaces.
The script and a readme file (DetectStudiesWithUnitsWithSpaces.Readme) are available on the product ZIP file in the InstallSupport directory.
Parent topic: Checklist—Planning a migration
