Send the Reportable or Serious item to Argus only when the InForm user marks it as Ready-to-Send
Note: If you have both Adverse Event form(s) and a Safety Case form, the rule goes on the Safety Case form.
lab
Item |
Description |
When to use |
This rule is typically used when you want to indicate explicitly that the safety event information is ready to be sent to Argus Safety. You might use this rule when:
This rule can be used for a combined AE/Safety Case form or for a separate Safety Case form. |
Purpose |
Ensures that a safety event, marked as Reportable or Serious, is sent to Argus Safety only when explicitly marked as Ready to Send. Note: The case will be sent automatically after 24 hours of initial form submission. |
Triggering controls |
Y or N codelists for the following:
Action when rule is triggered |
Reportable or Serious item value is Y, and Ready-to-Send item value is Y:
Reportable or Serious item value is Y, but Ready-to-Send item value is N:
Ready-to-Send item value is Y, but neither the Reportable nor the Serious item value is Y:
Rule expression |
(!this.AEInfoSct.IsSerious.Empty && this.AEInfoSct.IsSerious.Value != 'N')|| (!this.AEInfoSct.IsReportable.Empty && this.AEInfoSct.IsReportable.Value != 'N')? (!this.AEInfoSct.IsReadyToSubmit.Empty && this.AEInfoSct.IsReadyToSubmit.Value != 'N') ? _SaveToDb("SafetyConstants.IsReadyToSend", GetTrialName()) : _ SaveToDb("SafetyConstants.IsReportableOrSerious", GetTrialName()): _ SaveToDb("SafetyConstants.IsCancelled", GetTrialName() |
