Overview of viewing synchronization connections
The Sync Connections tab on the CIS Synchronization Adapter page displays a list of current synchronization connections and provides details about each synchronization connection.
- Sync Connections tab of the CIS Synchronization Adapter page - Fields.
Field
Description
Auto-refresh
- If selected—The page refreshes automatically at the interval specified on the Settings tab of the My CIS page.
- If not selected—The page does not refresh automatically.
Create New Sync Connection
Click to display the first page of the CIS Synchronization Connection Wizard and start to create a new synchronization connection.
Status (filter)
List of possible synchronization connection statuses. To display only synchronization connections in a specific status, select the status from the drop-down list. Possible status filters are:
The columns of the synchronization connection table display information about each synchronization connection.
CIS Sync Name
Name of the synchronization. This is the name entered when the synchronization connection was created.
Last Sync Start (UTC)
Last time the synchronization started. Synchronization schedule time is stored as Universal Coordinated Time (UTC) time.
Last Sync Duration (min)
Number of minutes and seconds it took to complete the synchronization.
Next Sync Start
Next time the synchronization is scheduled to start. Synchronization schedule time is stored as Universal Coordinated Time (UTC) time.
Enabled state
- Yes—The synchronization is enabled. The synchronization runs using the schedule you define.
- No—The synchronization is disabled.
Note: If a synchronization is disabled, you can start the synchronization manually by clicking Sync Now.
Status (synchronization connection)
Run status of the synchronization. A synchronization can have the following status:
- Green Square—Indicates that the last synchronization was successful and all transactions for that synchronization were sent to both the InForm software and the Clintrial software. However, this column only displays the status for the last synchronization and does not indicate that all transactions have been synchronized. If additional transactions were generated by the InForm software or the Clintrial software, these transactions do not appear until the next synchronization completes.
- Orange Diamond—Indicates the synchronization is still running.
- Red Triangle—Indicates an error has occurred.
- Adapter tab of the Admin Adapter page - Fields.
Field
Description
The top section of the page displays information about the adapter.
Auto-refresh
Name
Name of the adapter.
Status
- Green check mark—Adapter status is OK.
- Red X—Adapter status is Error.
Product Type
Product with which the adapter is associated:
- CIS—For CIS Synchronization Adapters.
- Clintrial—For Clintrial Adapters.
- InForm—For InForm Adapters.
Adapter Type
Type of adapter:
- CIS Synchronization—For CIS Synchronization Adapters.
- Clintrial Admin—For Clintrial Adapters.
- InForm Admin—For InForm Adapters.
URL
URL for the adapter.
Enabled
- Yes—Adapter is enabled.
- No—Adapter is disabled.
If the adapter is an InForm Adapter, the lower section of the page displays information about the end points (trials) for the adapter.
Name
Name of the InForm trial.
Registered Name
Registered name of the InForm trial.
Status
- Green check mark—End point status is OK.
- Red X—End point status is Error.
Details
Link to additional information about an end point with an Error status.
You use the Sync Connections tab of the CIS Synchronization Adapter page to view and manage synchronization connections. From the Sync Connections tab, you can:
