Editing a Clintrial database instance
- Log on to CIS Administration.
The home page of CIS Administration appears.
- If the CIS Synchronization page is not your home page, select Admin > CIS Sync.
The CIS Synchronization page appears.
- Click Database Settings.
The Database Settings tab appears.
- In the Clintrial Database Instance table, click Edit next to the database instance you want to change.
The Instance, CISUSER Password, and Open Query State fields are enabled.
- In the Instance field, type a new tnsname for the instance.
- In the CISUSER Password field, type a new password.
Important: If you want to change this password, you must first change the Clintrial instance password for Oracle. What you specify for the CISUSER password must be the same as the Oracle password for the Clintrial instance.
- From the Open Query State drop-down list, select the Clintrial discrepancy status that corresponds to the InForm open Query status.
Click Update.
