To Modify Accessible RDCIs
- From the tree, select the Data Entry then, select Key Changes.
- Enter the Document Number and press the Enter key. The system displays a Forms message window with a message that the document with that number already exists.
- In the Forms window, click the Update Existing button.
- Update the necessary fields. Use Next Block to navigate to the associated RDCMs, where you can also make changes.
- Save to re-validate the Received DCI and Received DCMs.
- Exit.
Parent topic: Modifying or Deleting Locked RDCIs and RDCMs
