Modifying DCIs
Oracle Clinical allows you to modify a DCI after it has been logged in and data has been entered.
Use either Key Changes or Initial Log-in to modify header fields.
Use First-Pass Entry to modify the header blank flag, DCI comments, DCM comments, and DCM data comments.
Use Update, Second-Pass Entry, and Reconciliation to modify DCI header comments, DCM comments, and DCM data comments.
Use Update mode to modify response data.
Depending on the DCI/DCM status, you can use First-Pass Entry, Second-Pass Entry, and Reconciliation to update data.
Changes to DCI/DCM in certain statuses cause the system to display the Reason for Change window. Refer to the Accessibility section for additional information.
