Setting Up Test Study Design
When you create a live clinical study version, Oracle Clinical automatically assigns test sites, Investigators, and ten patient positions to it. This provides the framework you need to test your definitions. You can use Test mode layouts and forms as you would their Production mode counterparts, ensuring that they correctly represent the study's requirements.
When you enter data into a CRF, you specify or select Investigator, Site, Patient, Clinical Planned Events (CPEs), and Visits. Oracle Clinical uses Test mode data for Investigator, Site, and Patient information. However, Oracle Clinical uses the same CPE and Visit information for both Production and Test mode. (The data comes from the same tables.)
The test sites, Investigators, and patient position names that are included with the installation have a leading X to distinguish them from production data. If you need additional cases you can modify or add to this data. For example, you can modify the generated details in a patient position where you need procedures requiring different sexes or dates of birth.
If you modify or supplement these test objects, Oracle recommends adhering to a naming convention that avoids confusion with production data. Oracle Clinical prevents using test data in Production mode, but hard copy reports or SAS data sets with test data that have similar names to production data could cause confusion.
The Design Test mode systems are identical to their production counterparts. For instructions for using these utilities, refer to the references included in this list:
Testing Investigator Design: See Maintaining Investigator Records. From the Design menu, select Test a Study Design, then Investigators.
Testing Site Design: See Maintaining Site Records. From the Design menu, select Test a Study Design, then Sites.
Testing Study Sites: See Assigning Sites to a Study. From the Design menu, select Test a Study Design, then Study Site.
Testing Site Investigator Assignments and Details: See Assigning Investigators to Study Sites.
Testing Patient Positions Maintenance: See Maintaining Patient Positions. From the Design menu, select Test a Study Design, then Creating/Deleting Patient.
Linking patients to a test study: See Linking Patient Positions in Different Studies. From the Design menu, select Test a Study Design, then Patients, and click the Patient Positions button.
Maintain test study Patient Positions: See Maintaining Patient Positions for more information. From the Design menu, select Test a Study Design, then Patients, and click the Patient Positions button.
For more information , see:
Parent topic: Test Mode
About Test Mode Synonyms
Oracle Clinical creates the following private synonyms that point to the test tables or to the views in Test mode. When you access a Test mode option, Oracle Clinical creates synonyms for you that point to the test tables. Oracle Clinical drops the synonyms for Production mode.
Table 17-1 Synonyms
| Test Synonym | Production Mode Table or View |
ACTUAL_EVENTST |
ACTUAL_EVENTS |
ACTUAL_EVENTS1T |
ACTUAL_EVENTS1 |
ACTUAL_EVENTSVT |
ACTUAL_EVENTSV |
DISCREPANCY_ENTRIEST |
DISCREPANCY_ENTRIES |
DISCREPANCY_ENTRY_REVIEW_HISTT |
DISCREPANCY_ENTRY_REVIEW_HIST |
DISCREPANCY_MANAGEMENTT |
DISCREPANCY_MANAGEMENT |
INVESTIGATORST |
INVESTIGATORS |
INVESTIGATORST |
OCL_INVESTIGATORS |
SITEST |
OCL_SITES |
RXC_STUDY_SITEST |
OCL_STUDY_SITES |
STUDY_SITE_ROLEST |
OCL_STUDY_SITE_ROLES |
OPA_LEVEL_PRIVST |
OPA_LEVEL_PRIVS |
PATIENT_POSITIONST |
PATIENT_POSITIONS |
PATIENT_POSITIONS_VT |
PATIENT_POSITIONS_V |
RDC_AUDIT_VIEWT |
RDC_AUDIT_VIEW |
RDC_DISCREPANCIEST |
RDC_DISCREPANCIES |
RDC_PDF_VRVST |
RDC_PDF_VRVS |
RDC_VRVST |
RDC_VRVS |
RDCI_HISTORYT |
RDCI_HISTORY |
RECEIVED_DCIST |
RECEIVED_DCIS |
RECEIVED_DCIS_VT |
RECEIVED_DCIS_V |
RECEIVED_DCMST |
RECEIVED_DCMS |
RECEIVED_DCMS_VT |
RECEIVED_DCMS_V |
RECEIVED_PAGE_HISTORYT |
RECEIVED_PAGE_HISTORY |
RECEIVED_PAGEST |
RECEIVED_PAGES |
RESPONSEST |
RESPONSES |
RXC_STUDY_SITEST |
RXC_STUDY_SITES |
SITEST |
SITES |
STUDY_SITE_PATIENT_POST |
STUDY_SITE_PATIENT_POSITIONS |
STUDY_SITE_ROLEST |
STUDY_SITE_ROLES |
VALIDATION_REPORTED_VALUEST |
VALIDATION_REPORTED_VALUES |
VALIDATION_REPORTED_VALUES_VT |
VALIDATION_REPORTED_VALUES_V |
Until you move a study to production, all of your Oracle Clinical sessions for that study are in Test mode. When you are in Test mode, your Oracle account points to test tables. This condition applies even after you log out and log back in. You can check whether you are pointing to test or production tables by looking in the User Synonyms table in a SQL session.
Parent topic: Setting Up Test Study Design
