Add Custom Review Types
You create custom review types and their corresponding privileges in the CUSTOM REVIEW TYPES installation codelist in Oracle Clinical. This codelist comprises all user-defined review types and the privilege required for each of the review types.
You can define up to 444 custom review types for a DCI.
For more information, see:
Deactivate Custom Review Types
If you deactivate a custom review type from the CUSTOM REVIEW TYPES reference codelist in Oracle Clinical, the change takes effect as follows:
- In RDC, the inactive custom review type is available for search but with suffix
inactive
). However, the calculation of the CRT icon will not consider the inactive custom review type. - In RDC Data Entry window, reviewers with privileges for the inactive custom review
type and one or more active custom review types (so that they can still change
review statuses) can view audit history for the inactive custom review type,
which appears prefixed by (
inactive
- Log in to Oracle Clinical as an administrator.
- Navigate to Admin, Reference Codelists, and select Installation Codelists.
- In the Maintain Installation Codelist window, query for the CUSTOM REVIEW TYPES codelist.
- Under Reference Codelist Values, find the review type that you want to retire and deselect the Active checkbox.
- Click Save.
- If the custom review type is explicitly required based on the study DCI or GLIB DCI review requirement, the study manager or global librarian must also access the Maintain Study DCIs or Maintain GLIB DCIs form, respectively, at which point the inactive custom review type is removed, and then save changes. If this was the only custom review type that was required for the DCI, the DCI then inherits the study or installation default requirement, as applicable.
Parent topic: Add Custom Review Types
