5 Configuring Custom Review Types
To facilitate centralized monitoring in RDC, you can create custom review types, which are similar to the predefined Verify and Approve review types. By defining custom review types, you enable and can track reviews performed by users with a specific role, such as data manager, safety expert, or adjudicator.
You specify default custom review requirements at the installation, study, or DCI level, which can require that all, none, or some custom review types be performed on CRFs. You can define custom review types in the CUSTOM REVIEW TYPES installation codelist in Oracle Clinical together with a privilege for each, and then assign each privilege to the appropriate reviewer.
For more information, see:
- Review Statuses for Custom Review Types
- Define Custom Review Type Requirements
- Finding CRFs with the Review Not Required (RN) Status Set by Users
- Viewing Audit History for Changes in Custom Review Requirements
- Add Custom Review Types
- Assign Custom Review Type Privileges to Users
- Define Custom Review Type Activities
