Define Custom Review Type Requirements
You can define a default requirement for custom reviews at the installation, study, GLIB DCI, and study DCI level. The multi-level requirements can specify that all, none, or some custom review types are required by default for CRFs at a particular level. The default applies to entered CRFs with no explicitly set review status.
After you define custom review requirements, RDC users can search for CRFs requiring review and can see indicators on the CRF icon for the review status of CRFs; see Review Statuses for Custom Review Types.
In this section:
- Set Custom Review Requirement for the Installation
- Set the Custom CRF Review Requirement for a Study
- Set Custom Review Requirement for a GLIB DCI
- Set Custom Review Requirement for a Study DCI
Parent topic: Configuring Custom Review Types
The installation-wide requirement applies for all entered CRFs that do not have a review status that was explicitly set by a user.
Parent topic: Define Custom Review Type Requirements
You can set specific custom review requirements for CRFs in a study that are different the installation-wide requirement for a particular study. This requirement applies for all entered CRFs in the study that do not have a review status that was explicitly set by a user.
- Log in to Oracle Clinical as an administrator.
- Expand the Design node and select DCI Form Local Study Settings.
- Select the study or switch to the study for which you want to set the requirement.
- At the bottom, expand the Default DCI Custom Review Requirements group of settings by clicking the plus icon to its left.
- For the setting Allow CRF status change to RN when review is required?,
specify
Y
orN
in the Value column.A value of
Y
allows reviewers to change the CRF review status to Review not Required even when the study setting, which you set in the next step, is set to require custom reviews. - For the setting Custom Reviews are Required, specify
Y
orN
Y
requires that all custom review types be performed for all CRFs in a study. - Click Save.
If you specify custom review requirements for a study DCI, updates to the study-level custom review requirements will not override the study DCI. If you want to enforce the study-level requirement in such a DCI, you have to manually change the study DCI custom review requirements. See Set Custom Review Requirement for a Study DCI for instructions.Enforce the Installation-wide Custom Review Requirement for CRFs in a Study
If a study has a custom review requirement defined, the installation-wide default is not enforced for that study. You can apply the installation default to clear the user-defined requirement for the study.
- Select the study or switch to the study for which you want to edit the requirement.
- For the setting Allow CRF status change to RN when review is required?, select the checkbox Inherit From Local DB Setting. The column Local DB Value shows the inherited value.
- For the setting Custom Reviews are Required, select the checkbox Inherit From Local DB Setting. The column Local DB Value shows the inherited value.
- Click Save.
You can set a different custom review requirement than the default that is defined at the installation or study level, which may require all or none of the available review types for all CRFs. At the individual DCI level, you can refine the requirement by setting all, none, or only some custom review types to be required for CRFs of the DCI. This requirement applies for all entered CRFs of the DCI that do not have a review status that was explicitly set by a user.
You can set a different custom review requirement than the default that is defined for the installation or study DCI. This requirement applies to all entered CRFs in the study DCI that do not have a review status that was explicitly set by a user.
Tip:
You can specify custom review requirements for any DCI, whether active, provisional, or retired. You may want to define requirements even for a retired DCI in case a CRF, entered against the retired DCI, is updated.Parent topic: Define Custom Review Type Requirements
