Install the Oracle Clinical Front End Components
To install the Oracle Clinical Front End components:
For more information, see:
- Review the Installation Log Files
- Set Remote Method Invocation (RMI) JDBC Security to Secure
- Restart the Computer
- Add WebLogic Data Sources If Using Multiple Databases
Parent topic: Install the Oracle Clinical Front End
Also, review the log files located in the C:\opapps54\log folder.
Work with Health Sciences Support, if necessary, to resolve any errors.
Parent topic: Install the Oracle Clinical Front End Components
- Log in to the OPADomain WebLogic Server.
- Go to Summary of Servers, select Managed Server of OPADomain, select General, and click Advanced.
- Change the RMI JDBC Security setting to Secure.
- Click Save.
- Click Activate Changes.
To ensure that all configuration changes are initialized:
- Restart the computer before you continue with the next task in the installation process or before you install Oracle Clinical Reports Server.
When you run the Oracle Clinical Installer, it sets up two data source connections, one for OPA and one for RDC Onsite, from the WebLogic Server (WLS) to the database you specify in the Installer screens.
If you plan to use more than one database:
- Create a WLS data source for RDC for each additional database.
If you also are using TMS on multiple databases:
Instructions are in the Oracle Clinical Remote Data Capture Onsite Administrator's Guide and the Oracle Thesaurus Management System User's Guide.
