3 Review and act on discrepancies
How do I create a discrepancy?
Go to Home, then
Data Management, then Data Review, then Listings. See
"Create discrepancies" for details.
Tip:
In Release 2.4.8 there are two Discrepancies pages, one old and one new.
Reach the new one by navigating to
Data Management, then Discrepancies. This page has an
enhanced user interface.
Reach the old one by navigating to
Discrepancies. This page has more powerful filter and sorting
capabilities.
Parent topic: Review and act on discrepancies
Find discrepancies
There are two ways to find discrepancies that can be used together or separately: the filters in the left pane and the fields at the top.
Use the quick filters on the left pane
These look for the exact values you enter.
Click the Data Management icon
at the top of any page.
Select Discrepancies.
In the left panel, search for any combination of the following: Clinical Data Model, Listing, Site, Subject, Visit, Discrepancy State.
Start at the top and work down. Your choices in the lower fields are limited by the values in the upper fields. You can select more than one value by clicking in the field again.
Click Apply.
(Optional) To save these criteria for future use, click Save, name the filter, and click Save and Apply.
Tip:
Saving a filter allows you to modify it one criterion at a time, saving after each change.
Use the search fields at the top to add filter criteria.
Tip:
If you need more granular filters, go to the old Discrepancies page. See Use filters to find data and discrepancies.
Click the
Home icon at the top of the page.
Click the
Data Management icon at the top of the page.
Click Data Review.
Click the Discrepancies tab.
Click the
Filter icon.
To clear the filters, click Clear.
To view data after clearing, click Apply, without filters or with different ones.
Parent topic: Find discrepancies
You can enter a partial value here to find all records that contain that value. For example, if you search for Subject ID=CA, you find all subject IDs that contain CA, unlike the quick filters that find only the exact value entered.
If there are quick filters in effect when you search in these fields, the system applies the filters and searches on these values within the filter results.
If there are no quick filters in effect, the system searches across all discrepancies.
Tip:
To see which quick filters are in effect, click the down arrow in the
Filter: ON indicator at the top of the page.
In the drop-down list above the discrepancies table, select what to search on, for example: Category, Datasource, Days since last state change, Discrepancy text. The choices depend on the columns your organization uses.
Enter a value in the text box.
Click the
Search icon.
Tip:
If you need more granular filters, go to the old Discrepancies page. See "Use filters to find data and discrepancies".
Click the
Click the
Click Data Review.
Click the
Filter icon.
To clear, remove the value and click Refresh in the upper-right corner.
Act on a discrepancy
- Change the state or send to InForm or another system
- Add a comment
- Change discrepancy text or category
- Export discrepancies on lab data
Add a comment
- Click the Data Management icon
at the top of any page. - Select Discrepancies.
- Find discrepancies using the filters on the left and top of the page.
- Select one discrepancy.
- In the right panel, click Add Comment.
- Enter the comment and click Submit.
Parent topic: Act on a discrepancy
- In the right panel, click Edit.
- Edit the discrepancy text and/or select a new category.
- Click Submit.
To send discrepancies to a lab, create a file and email it manually.
See more information about a discrepancy
- View the full record containing a discrepancy
- View the record in its source system
- View the discrepancy in its source system
From the View drop-down on the right, select Full Record.
To see a particular column:
Enter part of its name in the Search field.
Click the Search icon.
(Optional) Select Show Only Changes to see only items with different current and original data values.
Parent topic: See more information about a discrepancy
- From the View drop-down on the right, select Data in System.
- When the source system opens, log in.
- From the View drop-down on the right, select Discrepancy in System.
FAQs
- Acting on a discrepancy FAQs
- InForm query and discrepancy FAQs
- Lab data discrepancy FAQs
- TMS discrepancy FAQs
- Can I take an action on multiple discrepancies at once?
- Why don't I see the action I want to apply?
- Can I send discrepant data items to multiple sources?
- Why can't I send a particular data item to another source?
Parent topic: FAQs
Yes, but you should select discrepancies that are all in the same state. The discrepancies may also need the same tag depending on how your company uses the system, and may need to be from the same data source. The system only displays actions that are valid for all the selected discrepancies.
Parent topic: Acting on a discrepancy FAQs
If you selected multiple discrepancies, the system displays only actions that apply a valid next state for all the selected discrepancies. If you select discrepancies that do not share a valid action, the system lists no actions. You must change your selection to a set of discrepancies that are in the same state. They may also need to have the same tag applied.
If you selected a single discrepancy and the discrepant data point is derived from multiple data values from different sources, the system uses the data source identified as on the preferred path in the transformation to determine which routing action to enable. If no action is available to send the discrepancy to the source you need, you may need to enter the discrepancy against the data point in the source data model.
If a single discrepant data item is derived from data in more than one source, you can only send the discrepancy to InForm if an InForm data item is designated as being on the preferred path. You can always filter and use Export to Excel for sending a discrepancy to a lab.
The system uses the preferred path source specified in the transformation or validation check to determine where you can send the discrepancy. If no action is available to send the discrepancy to the right source, you can go to the Listings page, change to the source data model, and create a discrepancy against the data item there.
Add a comment to the current discrepancy detailing what you did.
- Can I change the state of a discrepancy that was loaded from InForm?
- Can I create a discrepancy in DMW on a data item that originated in InForm?
- Can I send a discrepancy to InForm?
- Why can't I open InForm and see a discrepancy there?
- What happens to the discrepancy after I send it to InForm?
- If I don't send the discrepancy to InForm, can InForm users act on the discrepancy?
- Before I send the discrepancy to InForm, can I act on it?
Parent topic: FAQs
You can only move discrepancies/queries to the Answered state in InForm. You can close them in either system.
This is true no matter which system the discrepancy/query was created in.
Parent topic: InForm query and discrepancy FAQs
Yes. Validation checks can also create discrepancies on a data item originating in InForm.
Yes. When you send a discrepancy on an InForm data item back to InForm, you create a new query in InForm.
InForm does not accept discrepancies on data that is hidden in InForm. Any resolution must occur within DMW.
You have to wait until data has been reloaded from InForm after sending the discrepancy.
InForm users can act on the discrepancy using the same rules that apply to queries. InForm users can also correct the underlying data item.
Changes made in InForm are loaded into DMW during the next scheduled data load. The discrepancy is then "in" DMW and cannot be sent to InForm again, though updates made in DMW are sent to InForm.
No. InForm users can change the underlying data item, and that change is loaded into DMW during the next scheduled data load, but they can't act on the discrepancy.
Yes. In DMW you can apply an action that changes the state of the discrepancy and must supply a reason for the change. The state change and reason for change are sent to InForm almost immediately.
- Can I create a discrepancy on a data item that originated in a lab?
- How do I send these discrepancies to the lab?
Parent topic: FAQs
Yes. Validation checks can also create a discrepancy on a data item that originated in a lab.
Parent topic: Lab data discrepancy FAQs
You can use Export All to Excel to export discrepancies to a spreadsheet and manually send them to the source lab. Lab personnel can then respond or change the underlying data item and load the changes into DMW, and you can act on the discrepancy in DMW.
When you use the Export All to Excel option to send discrepancies to a spreadsheet, all discrepancies that meet the current filter criteria are included, even if they are not visible on the screen.
- What does it mean when a discrepancy's category includes "TMS"?
- What do the different TMS Discrepancy Categories mean?
- What should I do with a TMS discrepancy?
- Why is a query on a different item in InForm than in DMW?
Parent topic: FAQs
If your study is set up to use Oracle Thesaurus Management System (TMS) for coding source data to standard terminologies, or dictionaries, TMS processes designated data items with new or changed data during DMW transformation. If TMS is able to automatically code a designated source term to a dictionary term, it does so and derives specified data back to DMW.
TMS creates a discrepancy when it cannot automatically code a data item to a dictionary term.
Parent topic: TMS discrepancy FAQs
TMS in Progress prevents updates in DMW while the data item (term) awaits manual classification in TMS.
TMS Evaluation means that the item or discrepancy has been updated either in the source system or in DMW, and triggers autoclassification on the term in TMS during the next transformation. No updates can be made in DMW while the category is TMS Evaluation.
TMS DM Review means that the data manager should review the discrepancy in DMW.
TMS Inv Review means that the discrepancy has been sent to InForm as a query for review by the investigator. The system also sends any subsequent updates to the discrepancy to InForm.
You can use a Discrepancy Categories filter to help process these discrepancies.
You can only review the discrepancy in DMW. TMS discrepancies must be resolved in either TMS or the source data system.
A TMS user can either:
Classify the data item manually. TMS then closes the discrepancy and derives data to DMW.
Send text to DMW as discrepancy text describing a problem with the data or an action required. For example, if the data item is "headache and nausea," the message could be "Split the term."
A source data system user can correct the term so that it can be classified in TMS.
Tip:
A discrepancy can be updated in the source system and in TMS at the same time. This may cause conflicts. For example, an InForm user might close a discrepancy thinking the term is a valid one while TMS does not recognize it. In this case, even though the Closed status is loaded into DMW, closing the discrepancy, TMS opens a new discrepancy when autoclassification fails.
This can happen if your study designer set up Coding Maps in Central Designer to purposefully attach a query to a different form item than the one it was raised on. This feature is intended for use with Central Coding.
If the same form item is set up for coding in TMS through DMW, when the discrepancy is sent to InForm the Coding Map routes the query to its mapped item.
Review and act on discrepancies in the old UI
- How do I create a discrepancy?
- Act on a discrepancy
- See more information about a discrepancy
- Show blinded data
Go to
Create discrepancies for details.
Parent topic: Review and act on discrepancies in the old UI
You apply actions to discrepancies to move them from one state or tag value to another and/or to send them to InForm or to a spreadsheet to be sent to a lab. See the following for details.
- Apply an action to change the state or send to InForm
- Add a comment to a discrepancy
- Edit discrepancy text
- Export discrepancies for a lab
Click the
Export to Excel icon to generate an .xls file that includes all discrepancies that meet the current filter criteria, even if they are not visible on the screen.
You can then manually send the spreadsheet to a source lab. Lab personnel can respond or modify the underlying data item and load the changes into DMW.
- View discrepancy details
- View discrepancy history
- View a discrepancy in its source system
- View data in its source system
at the top of any page except the new Discrepancies page. - Select Data Review.
- Select the Discrepancies tab.
- The Details pane for the selected discrepancy is on the bottom left. It includes:
Subject
Visit
Discrepancy: Discrepancy text. You can edit this by clicking the
Edit icon. You cannot edit text for discrepancies that have been sent to InForm.
Table: The database table that contains the discrepant value.
Model: The clinical data model that contains the data value against which the discrepancy was originally created.
If the model is InForm, the discrepancy originated as a query in InForm.
Item: The table column that contains the discrepant value.
Original Value: The original discrepant data value.
State: The current discrepancy state: Candidate, Open, Cancelled, Answered, or Closed. To change it, select Actions from the right-click or drop-down list.
Tip:
By default, Closed and Cancelled discrepancies are not displayed. To display them, use a States and Tags filter. See Discrepancy States and Tags filter.
Days in State
Category: The category assigned to the discrepancy, if any. You can filter by category. To change it, click the
Edit icon.
Created
Modified
Tag: The tag assigned to the discrepancy, if any. Some actions apply tags.
New Data: If Yes, the data value has been changed in the source system and the discrepancy has not been reviewed in DMW since then. When you or someone else clicks Display Full Record, the system considers it reviewed and sets this value to No. You can also set it to No.
View Query in InForm: When you click this icon, the InForm Login page opens. After you log in, the system displays the selected query in context.
View Data in InForm: When you click this icon, the InForm Login page opens. After you log in, the system displays the underlying data in context.
- The History pane for the selected discrepancy is on the bottom right.
- Click the
Refresh icon to view any changes that have occurred since you selected the discrepancy or last refreshed.
The history of the discrepancy is displayed with the most recent change at the top.
- On the bottom right, select the Display Full Record tab.
- Click the
The internal column CDR$SKEY displayed at the bottom contains the primary key values of the record separated by tildes (~). DMW uses this value to trace data lineage.
If a discrepancy was created on data from InForm or another EDC clinical data system, then sent to the system, and then data reloaded from that system, you can open the external system and view the discrepancy/query in context there.
- In the Details pane, click the View Query in External Source icon near the bottom.
To view data in context in InForm or another EDC clinical data system:
- In the Details pane, click the View Data in External Source icon at the bottom.
Show blinded data
If you have special privileges, you can choose to see sensitive, blinded data instead of masking values. The system tracks the times you view blinded data.
Show Sensitive Data is displayed by default. Click this icon to show blinded data.
Hide Sensitive Data is displayed when you have chosen to display blinded data. Click this icon to hide blinded data.
