4 Use filters to find data and discrepancies
This section has information on the complex filters available in the Listings
pages and in the old Discrepancies page under Data Review. Simple filters are available
in the new Discrepancies page that you reach by going directly to Discrepancies from the
Data Management icon.
Tip:
By default, no cancelled or closed discrepancies are displayed when you apply any discrepancy filter. To see cancelled or closed discrepancies, use a Discrepancy States and Tags filter.
Delete a filter
To delete a filter, select it from the drop-down list and click the
Delete icon.
You can delete filters you created. You cannot delete a filter if it is part of a filter group. Delete it from the group first.
Parent topic: Use filters to find data and discrepancies
Create a public filter
If you have special privileges, you can make a filter public. Data reviewers can:
Use any public filter.
Change public filter values temporarily.
Change public filter values and save them using a different name.
- Create a new filter. Give the filter a name and save by clicking OK.
- In the main Filter window, select Public from the drop-down to the right of the filter name.
Use filter groups
Filter groups apply multiple filters at the same time.
Filter group example
A filter group could contain the following four filters:
A shared Subjects filter named BOSTON HOSPITAL that filters for subjects at the Boston Hospital site.
A private Visits filter named CYCLE A that filters for records collected in visits that are part of Cycle A.
A public Discrepancy Categories filter called INFORM that filters for discrepancies on data that originated in InForm.
A private Discrepancy State Dates filter called LATEST that filters for records whose discrepancy state changed between specific dates. You need to update the dates each time you use the filter.
These filters are applied to the data at the same time, so that the system displays only data that satisfies the criteria for all filters.
If all filters are set to Keep Active, as long as you stay in the current study and lifecycle stage, the filters apply, if possible. If you view data in a table that does not have a column required for the filter—such as a Visit column or Site column in this example—the system ignores that filter.
Parent topic: Use filter groups
Filter Types
- Subject filter
- Visit filter
- Subject Visit Flags filter
- Visit Day filter
- Visit Date filter
- Record Flags filter
- Data Change Date filter
- Discrepancy Category filter
- Discrepancy Change Dates filter
- Discrepancy State Dates filter
- Discrepancy States and Tags filter
- Discrepancy User filter
- Discrepancy Origin filter
- Models and Tables filter
- Data Source filter
- Copy a custom listing
Subject filter
Filter records based on characteristics of subjects, including their country, site, investigator, or ID.
Parent topic: Filter Types
On the Listings page, use this filter to find records with particular Subject Visit flag values assigned. As you browse data in different models and tables, if the current table does not have a Visit column, the system ignores this filter.
On the Discrepancies page, use this filter to find discrepancies whose underlying data have particular Subject Visit flag values assigned.
If the data is in a table that is not a Subject Visit table, use the Record Flags filter under Data.
Visit Day filter
To create a filter based on the visit day number in the study design:
Record Flags filter
On the Listings page, use this filter to find records with particular Record flag states, or values, assigned.
On the Discrepancies page, use this filter to find discrepancies whose underlying data have particular Record flag states assigned.
If the data is in a Subject Visit table, use the Subject Visit Flags filter filter under Visits.
The Data Change Date filter displays records whose most recent update occurred during the time period specified.
The Discrepancy Category filter displays only records that have one or more discrepancies of the categories specified.
The Discrepancy Change Dates filter displays records that have one or more discrepancies whose most recent update occurred during the time period specified. To create a Discrepancy Change Dates filter:
The Discrepancy State Date filter displays only records that have one or more discrepancies whose most recent state change occurred during the time period specified.
Use this filter to find discrepancies in a particular state, with or without a substate (tag).
In the Listings page, the filter finds records with discrepancies that meet the criteria.
In the Discrepancies page, the filter finds discrepancies that meet the criteria.
Use this filter to retrieve discrepancies by the person who created or most recently modified a discrepancy.
Use this filter to retrieve discrepancies by the way they were created.
Use this filter to retrieve discrepancies by the table or data model against which they were originally raised.
Data Source filter
Use this filter to retrieve discrepancies by their original data source or data source type—for example, a lab or InForm.
FAQs
- How do I find...?
- How do data filters work on the Discrepancies page?
- What does the star mean?
- How do I know if any filters are applied?
- How can I tell which filters are applied?
- How do I turn filters off?
- Why can't I make my filters public?
How do I find...?
Discrepancies created or modified before or after a particular date? Create a Discrepancy State Dates filter.
All Open or Candidate discrepancies? Create a Discrepancy States and Tags filter.
Discrepancies on the same subject, site, investigator, or country? Create a Subject filter.
Discrepancies on data from the same lab? Create a Data Source filter.
Discrepancies assigned to my role for review? Create a Discrepancy States and Tags filter.
Discrepancies created by the same validation check? Create a Discrepancy Origin filter or go to Validation Check Listings in the Listings page.
Discrepancies from the same visit? Create a Visit filter.
Closed and cancelled discrepancies? Create a Discrepancy States and Tags filter.
Discrepancies I created? Create a Discrepancy User filter.
Other types of filters: Subject Visit Flags filter, Visit Day filter, Visit Date filter, Record Flags filter, Data Change Date filter, Discrepancy Change Dates filter,Models and Tables filter, Discrepancy Category filter.
When a filter is applied, the message "Filters On" appears. To see which filters are currently applied, click the Current Filters icon. To remove all current filters, click the Filter Off icon. To selectively turn off, turn on, or modify filters, click the Filter icon. See Use filters to find data and discrepancies
Parent topic: FAQs
When you go to the Discrepancies page from the Listings page with Keep Active selected for your filters, the system continues to apply the same filters, except:
Data Change Dates filters are ignored.
If any of the current Subject or Visit filters applies only to a specific data model, the system displays only discrepancies in that model.
If different Subject and Visit filters have different driver data models and they are applied at the same time, the system ignores all Subject and Visit filters.
A message appears when any of these situations occur.
Parent topic: FAQs
If you apply a discrepancy filter in a Listings page, records with discrepancies that meet the filter criteria have a
star icon.
Parent topic: FAQs
In the Listings page, the Filter drop-down is displayed as blue and says "Filter On":
In the Discrepancies page, "Filters On" is displayed in blue:
Parent topic: FAQs
In the Listings page, select
Current Filters from the Filter: ON drop-down.
In the Discrepancies page, click the
The Current Filters window lists the filters currently applied, with the following information:
Filter The name or, if it has no name, TEMPORARY_FILTER.
Filter Type
Class
Private: You created the filter.
Shared: Someone created the filter and shared it.
Public: Official filter that is always available.
Parent topic: FAQs
In the Listings page:
To turn all filters off, select
Clear Filters from the Filter: ON drop-down.
To clear selected filters, select the
Filters icon from the Filter: ON drop-down.
In the Discrepancies page:
To turn all filters off, click the
Clear Filters icon.
To clear selected filters, click the
Filters icon
Parent topic: FAQs
