Accept or reject suggested mappings
Once the automap process completes, a notification opens with: "Automapping suggestions require review and approval." You can accept or reject the suggested mappings. (For more details selecting tables to automap, see Use Automap.)
  1. Review all table and column mappings.
    The Type column shows the type of logic used to find the source column: Name Match, Alias Match, Datatype Match, or Partial Name/Alias Match.
  2. Clear any maps you do not want.
  3. To accept the maps, click Map > Review and Accept maps from the Transformation tab title bar.
