Can I use Oracle Thesaurus Management System in all three lifecycle stages?
In Development and QC you can send data to TMS, derive data for terms that can be automatically coded, and create DMW discrepancies for terms that cannot be automatically coded. These discrepancies will close only if the data is updated in such a way that it can be coded automatically.
Only Production has complete coding functionality. In addition to deriving data:
TMS creates omissions for terms that cannot be automatically coded. TMS users can code these terms manually.
DMW creates discrepancies that correspond to the omissions and sends them to InForm. You can export discrepancies on lab data to Excel and send the spreadsheet to the lab.
Parent topic: FAQs
