When I copy a table, sometimes validation checks and custom listings are included in the copy and sometimes not included. Why?
When you copy a table, the system checks if you have included all source tables for the validation checks and custom listings in the copy operation. If you have, the validation checks and custom listings are also copied.
If you have not included all the source tables:
  • If a validation check is in an ordered batch, you receive a warning.
  • For validation checks that are in an unordered batch, and for any public custom listing, the system does not give a warning and does not copy the validation check or custom listing.
If you need the validation check or custom listing, you can copy it separately.
