Install a clinical data model
After creating or modifying a clinical data model, you must install it to make it usable. See What happens during installation? and Installation requirements.
To install a clinical data model:
Click the Study Configuration icon
from the navigation bar. Then click the Clinical Data Models tab.
Select the lifecycle in which you want to install the model.
If it is an input model, click the
Suspend Data Load icon.
Select the model and click Check Out.
Select one option from the Install drop-down:
- Install upgrades all tables and does not delete any data.
- Full Install drops and replaces all tables, deleting all data. Full
installation is not available in the Production lifecycle stage.
These options are available only if the object is installable:- The Version and the Installable Version must be the same.
- See Installation requirements.
To see the updated job status in the Install Status field, click the
Refresh icon. The final status doesn't appear until the job completes and you click Refresh.
To see the log file, select Get Install Log from the Actions drop-down list.
Back to Set up clinical data models
Parent topic: Set up clinical data models
