Expand Default Listings listings in the left panel. Then, expand a
clinical data model from the list.
Select a listing to open it.
Select the row with the record you want to flag, right-click anywhere in the
row and click Assign Flags. Or, click Flags > Assign
Flags. (To assign the same flag to multiple records, select the records
by pressing the Shift or Ctrl key while you select records.) The
Assign Flags dialog box opens.
Tip:
You can skip the remaining steps and use keyboard shortcuts
to assign a flag to a record by pressing Ctrl+Alt+F. Use the down
arrow keys to select options and press Tab to navigate to fields
and buttons.
In the Flags field, select the previously created flag name you want to
use from the drop-down list.
In the States field, select the previously created state name from the
drop-down list. The names are associated with a high, medium, or low flag state.
Click Assign. You can see the flag state in the first column of the
listing (up and red for high state, sideways and yellow for medium, or down and
green for low).
Tip:
If a data load
completes while you were viewing the page, you see a prompt to refresh the
page and Oracle DMW cannot assign the flag. Click the Refresh icon and check the data. If the flag still applies, assign it again.
