Review data
The following topics describe how to view discrepancies in a listing, view details, assign and remove flags, view data lineage, and reprocess discrepancies.
- View a single record from data listings
You can access a view of a single record that displays all of the columns on the Listings grid in a vertical manner. This can help you focus on one record at a time while being able to vertically scroll through the information. - Compare records in data listings
You can select up to 100 records within the Listings grid to compare in a focused, vertical view. This may be helpful if you want to review and analyze multiple records without scrolling horizontally across the entire Listings grid. - View Subject Summary
You can see the overall status of all forms and visits completed for a patient in a view called Subject Summary, similar to InForm's Time and Events Schedule. The Subject Summary uses color-coded cells and icons that allow you to quickly view the status of any critical CRFs. - View discrepancies in the Listings page
- View discrepancy details
- Show all discrepancies on one data item
- Assign and remove flags
- Show flags assigned to a record
- View data lineage
- View data in InForm or another system
- View InForm Comments
You can view item and form level comments entered in InForm on DMW's Default Listings UI as well as track the review progress in DMW by marking the comments as reviewed. - View InForm Answer History
You can access real-time InForm Answer History detail associated with any data point directly in the Default Listings grid during review - Use keyboard shortcuts on listings
