Expand Default Listings in the left panel (Default Listings,
Custom Listings, or VC Listings). Then, expand a clinical data
model from the list.
Select a listing to open it.
Select a data item that originated in InForm or a system connected through the
generic connector.
Right-click and select View Data in External Source.
Log in to InForm or whatever EDC system the data came from.
If the selected DMW data item has more than one source data item, the system displays the one on the preferred path.
Tip:
If you see a discrepancy in DMW that should have been sent to InForm or another source but wasn't, it may be that the process of sending the discrepancy to InForm failed. You can check this and fix it on the Home page. See Reprocess discrepancies that failed to be sent.
View Data in External Source is not supported for Clinical One.
