Expand Default Listings, Custom Listings, or VC Listings
in the left panel. Then, expand a clinical data model from the list.
Select a listing to open it.
Click anywhere in the row of the record.
Right-click and select one of the following to open a graphical representation
of the source, target, or preferred path:
Show Preferred Path If there are multiple source
data items, one must be designated as preferred when the
discrepancy is created by a validation check or a person. The system
applies the discrepancy to the data items in the preferred path.
View Source Data to see upstream data that
contributed to the selected data item.
View Target Data to see downstream data that the
selected data item contributes to. Target data is not available in
the Validation Check Listings page.
Click the tabs at the top of the graphic to display the source, target, or
preferred path.
