Compare records in data listings
You can select up to 100 records within the Listings grid to compare in a focused, vertical view. This may be helpful if you want to review and analyze multiple records without scrolling horizontally across the entire Listings grid.
To return to the previous view of the Listings interface,
click Exit Comparison.
Parent topic: Review data
