Expand one of the listings in the left panel (Default Listings,
Custom Listings, or VC Listings). Then, expand a clinical data
model from the list.
Select a listing to open it.
Click inside the Find in Column field at the top of the table to open
the Columns drop-down list.
Tip:
You can skip the remaining steps and use keyboard shortcuts
to access the Find field by pressing Ctrl+Alt+S. Start typing a
word and press the space bar to open the drop-down list. Then use the
arrow keys to select an option. You can press the space bar again to
open more options and build an equation. When done, press Tab to
navigate to the Apply icon and press Enter.
Press the space bar to open the Operators drop-down list. Build the
find criteria you need. For example, you can select equals (=),
contains, starts with, greater than or equal to (>=).
To enter text (string values), add single quotes around the text
(for example, 'Boston').
Tip:
When searching
or filtering with string values, we recommend using the contains
operator. This is because Oracle DMW allows multiple spaces (such as leading and trailing blank spaces) in
data displayed on the Listings and Discrepancies interfaces.
Click the Apply icon to apply the find. (Click the Clear icon to clear the Find criteria.)
