After you select a study, do one of the following:
If you selected a study from Study Manager, click
Data Management in the navigation bar and select Discrepancies
from the drop-down menu.
If you selected a study from Home, you can navigation to the
discrepancies interface by clicking any of the data sets in the graphs on
the Discrepancy Dashboard. For more information, see Use the Discrepancy Dashboard.
Find the discrepancies you need to locate using the filters on the left panel
or the top of the page. (See Find discrepancies for details on using the filters.)
Select a discrepancy.
In the right panel, click Edit.
Tip:
You can skip the
remaining steps and use keyboard shortcuts to edit one discrepancy at a time
by pressing Ctrl+Alt+E. Edit the Discrepancy field (if
available). Press Tab to navigate to the Category field (if
necessary), use the down arrow key to open the drop-down menu and select an
option. Press Tab to navigate to Submit and press
Enter.
Edit the Discrepancy or Category fields or select an
Action. When you select an Action, you can also choose an associated
Reason for the action and add a Comment. You can also select
or clear the Allow Auto Close option.
