- Data Review Guide
- Advanced: Run jobs and check history
- Check if data files loaded
- View data files not processed
- Click Study Manager in the navigation bar and select a study from the Studies panel.
- Click the Files Not Processed tab to open a table with uploaded files
that did not load into the selected study.
A file may not load into a study for any of these reasons:
It is misnamed or uses the different capitalization compared to the file specification defined for the clinical data model.
There is a mistake in the File Specification regular expression defined for the model.
There is a matching File Specification, but the end date passed.
There is a matching File Specification, but data loading is suspended.
There is a matching File Specification, but the model is not installed.
- View unprocessed files.
Columns include:
- File Name: Name of the file.
- Path: Path to the file location.
- Status: The possible statuses are:
DETECTED: The file has been detected in the watched folder but has not yet been submitted.
MISSING: The file was detected but deleted before the scheduled deletion or archive date.
DELETED: The file was deleted by File Watcher as scheduled.
ARCHIVED: The file was archived by File Watcher as scheduled.
- File Type: The type of file.
File Modified: The modification date of the file on the file system.
Detection Date: The date and time the file was detected, using the date and time in the DMW database.
Archive Date displays the scheduled archive date before the file is archived and the actual archive date afterward.
Archiving is not supported in this release.
Deletion Date displays the scheduled deletion date before the file is deleted and the actual deletion date afterward.
Date Missing: If the file is overwritten or removed from the file system before it is archived or deleted, then the Date Missing is store here.
File Error: Information about the problem.
Parent topic: Check if data files loaded
