Signal Management Refreshes page
On the Signal Management Refreshes page, you can view refresh runs of signal configurations.
You must have Manage Signal Configurations user permission to perform the following actions.
  1. In the left navigation pane, click the Settings icon (Settings icon).
  2. In the Configure System section, click Manage Signal Configurations.
  3. Click Refresh in the Row Action menu (Row Action menu icon
    Row action menu
    ) from the column, if you work with the multi-enterprise enabled Argus configuration.
    If the message, You do not have permission to refresh this configuration, appears at the top of the page and the Submit button is disabled, you don't have the necessary permission to perform a refresh.
  4. Click Manage Refreshes.
Arrange and extract data
Use the links at the top of the page to configure and download the data appearing in the table.
Select the Signal Management Configuration drop-down menu to filter the table to a specific configuration, if needed.
Row-specific activities
The following options appear in the Row Action menu (Row Action menu icon) for each refresh:
In the new window, you can Print Helpor Closethe generated table.
Table 10-3 Field descriptions—Signal Management Refreshes page
Field Description
ID
Identifier assigned automatically to the refresh when the refresh was created. Each ID is unique and is not re-used if the refresh is deleted.
Signal configuration name.
Data As Of
As of date for the refreshed data, if the data is timestamped.
Created
Date and time when the refresh was created.
Created By
Role or name of the user who created the refresh.
Start date
Date and time that the refresh was executed.
End date
Date and time that the refresh was completed.
Status
Status of the refresh run. The column remains empty until the refresh has completed or failed. Statuses include:
  • Canceled: The refresh was canceled while the job is being performed.
  • Completed: The refresh completed successfully.
  • Completed with warnings: The refresh completed but encountered issues.
  • Error Occurred: The refresh failed.
Warnings or errors encountered during a refresh appear on the Jobs for Refresh page.
