HDR Messaging Toolkit
Oracle Healthcare Data Repository (HDR) is a healthcare application development platform that exchanges healthcare information with external applications using the HL7 Version 3 Messaging Standard.
HDR ships with predefined message specifications for a comprehensive set of domains (subject areas), such as Encounter Management, Patient Care, Lab, and Public Health. Each such specification is called a Message Type. For each predefined Message Type, the inbound and outbound message processors have access to Message Type related files and data (XSD, MIF, Composite Message Schema, cmetinfo.coremif, and seeded metadata) that help them use and generate conformant XML instances.
The HDR Messaging Toolkit (MTK) provides you with a mechanism to specify custom message types, to facilitate HDR interoperation with other healthcare applications, and to suit your specific business requirements. MTK lets you perform validation and setups necessary to support custom messages types.
MTK Workflow
The following figure displays the process for creating and persisting custom message types using MTK:
Figure 9-4 Workflow for Creating and Persisting Custom Message Types Using MTK
To create and persist a new custom Message Type using MTK:
- Create an RMIM for a custom message type in any one of the following
ways:
- Designing the RMIM from scratch.
- Modifying an Oracle-published artifact to suit your business requirements. For more information on Oracle-published artifacts, refer to the Oracle Healthcare Data Repository Conformance Specification.
- Using an HL7 normative artifact. For more information, refer to the HL7 website (www.hl7.org).
- Generate the associated schema and MIF files. If the Message Type has any Common Message Element Type (CMET) references (either Oracle-published or custom) you must create a cmetinfo.coremif file.
- Load the XSD and MIF files into MTK. MTK performs some tasks as described in the following sections and generates reports.
- Use these reports to configure HDR to support these custom Message Types.
For more information on how to implement a new Message Type, refer to the Implement a New Message Type section.
The process of testing a custom message using MTK does not affect the data in HDR or existing configurations of HDR.MTK accepts the XSD, MIF, and cmetinfo.coremif files of a custom message type as the input and performs the following:
- Validates inputs.
- Generates the configuration reports.
- Generates instances with minimal manual intervention.
- Tests the instances for compatibility with HDR.
- Sets up Message Type.
Validating Inputs
MTK validates the inputs for the following:
The Message Type must have both the XSD and MIF files.
The custom CMETS referenced by Message Types must be present.
The cmetinfo.coremif file must be provided if the Message Type has any reference to the CMETs.
The contents of the corresponding XSD and MIF files must match.
After successful input validation, MTK loads the submitted artifacts into a test folder and generates related metadata.
Generating Configuration Reports
MTK generates configuration reports to help you port (or create) configurations related to the custom message into the production environment. These reports are generated in plain text or CSV format. The downloaded configuration can be loaded into a different HDR instance by using the respective messaging configuration service or by converting the data into SQL loader format.
Use these reports as an aid for creating the configuration reports to set up the message type in the production environment. These reports are not to be considered as the actual report.
Report Name |
Report Format |
Description |
Master Catalog |
CSV |
Lists the Acts, Roles, and Entities missing from Master Catalog for a given Message Type. You can use this report to create the appropriate Act Concept configurations in the production environment. |
Side Effect Configuration |
CSV |
Lists all objects that require side effect configurations for a given Message Type. This report lists the side effect configurations for a given Message Type with the master catalog entries relating to the code type ANY. The reference modifier used in the report for the objects will be Create or Overlay. You can use this report to create the appropriate Act Concept configurations in the production environment. |
Act Concept Configuration |
Plain Text |
Lists the ambiguous complexes found in the Custom Message Type Schema. You can use this report to create appropriate Act Concept configurations in the production environment. |
Generating Instances
Based on the constructs available, MTK generates one or more message instances. MTK uses dummy data to generate message instance. The data for the message instance will be drawn from the data seeded in HDR. MTK follows certain rules and logic while generating the instance.
Testing Instance
MTK tests the instance for the following:
Generation of configuration data: Inbound Message Processor (IMP) and Outbound Message Processor (OMP) configurations required by HDR to process a Message Type are created by MTK. These configurations will be rolled back after completing the test. For information on Sender, Receiver, Interaction, and Trigger event ID, refer to the Oracle Healthcare Data Repository HL7 Version 3 Conformance Specification.
Persistence of the generated MTK message instance into HDR using IMP: Once the instance(s) are generated, MTK invokes the IMP services to persist the message.
Generation of OMP instance: After persisting the message instance(s) successfully using IMP, MTK invokes OMP services to generate outbound instances.
Logging of output status along with Test ID: A unique Test Id will be generated for each test requested. The format of the Test Id is {ArtifactID}_{User ID}_{Test Date}.
Messaging Toolkit (MTK) Services
Use the oracle.apps.ctb.message.mtk package for this purpose.
Following are the MTK services:
oracle.apps.ctb.message.mtk.MtkTestService -
oracle.apps.ctb.message.mtk.MtkProductionLoadService
For detailed description of the APIs provided by these MTK services, refer to the HDR Javadoc.
HL7 Message Development Process
To utilize MTK to set up custom message types, you must understand the HL7 V3 process by which message types are specified.
The following steps summarize the MTK process for specifying message types:
- Develop storyboards and use cases that provide requirements for the content and transactions of messages.
- Use the HL7 RMIM Designer to produce an RMIM for a message type based on the content requirements from the previous step. Refer to the HL7 website (www.hl7.org ) for more information on RMIM Designer.
- Use the HL7 Schema Generator to convert RMIM Designer output into XML schema definition files (XSDs) and Message Interchange Format files (MIF). Refer to the HL7 website (www.hl7.org ) for more information on Schema Generator.
For each type of message specified, one pair of XSD and MIF files are produced that define the structure and constraints of the message. In addition, if CMETs were used in defining the message a cmetinfo.coremif file is generated.
A new Message Type can be implemented in HDR using the MTK Services.
The following are the prerequisites for using MTK:
Tools
Either download the tools provided by HL7 or use your own tools to generate the Schema and MIF files of a new Message Type. The tools used to generate a schema must also generate the required MIF files.
MTK is tested with artifacts created on:
HL7 RIM repository v2.14.1
RMIM Designer - 4.3.2
RoseTree - 4.0.12
Schema Generator - 3.0.4
Concept Lists
Identify from the Javadoc the Concept List used by the attributes of the new Message Type's objects. Ensure those Concept List have concepts in them.
If any of the Concept List used by a new Message Types Object attribute is empty, an error is thrown by MTK and the Message Type is not processed.
Datatypes and VOC files
datatypes.xsd, datatypes-base.xsd, and voc.xsd files are available for download from the Test Message Types window of the MTK Service. You can use these files in the schema generation tool to create a Schema and MIF files for the new Message Type.
Procedure
The following figure illustrates the process of implementing a new message type.
Figure 9-5 Implement New Message Type Using MTK
Test a New Message Type
Use the MTK Service Functions or MTK Services to test a new Message Type. Ensure that you have the following inputs for the testing process:
Message Type's Schema and MIF files.
Schema and MIF files of the custom CMETs referenced by the Message Type.
cmetinfo.coremif file listing all the CMETS (Oracle published and custom) referenced by the Message Type. Note that the entries of the non-referenced CMET in the cmetinfo.coremif file are ignored.
Comments relating to the test.
MTK uses the following process to test a new Message Type:
Verify the Test Files
This step is the final step in testing the Message Type and is required to verify if the instance generated from MTK and the one generated from HDR using OMP are the same with the exception of known differences. Once the test process is successful, download the MTK and OMP generated instance using the hyperlinks displayed in the MTK Service. Use a file compare utility, to verify the instances.
MTK does not provide an option or tools to compare MTK and OMP generated instances.
Set Up Message Types
Setting up Message Types is required if messages based on the Message Type have to be processed by HDR. To set up successfully tested Message Types in HDR:
Loading Message Types
Configuring IMP and OMP
Load Message Types
For messages to be processed, the files relating to the Message Type must be loaded onto the server. To load Message Type provide the following inputs:
XSD and MIF files of the Message Types.
XSD and MIF files of the CMETS referenced by the Message Types. Note that only custom CMETS must be provided. Do not provide any Oracle published CMETS if the Message Type references these.
cmetinfo.coremif file must have a list of all the CMETS (Oracle published and custom) referenced by the Message Type.
MTK Services: Refer to the Setting Up a New Message Type section for details on loading successfully tested custom Message Types onto a production server using Java API.
Configure IMP and OMP
In IMP, configure the following:
Trigger Event
Interactions
Sender
Sender Interaction
Sender Side Effect
In OMP, configure the following:
Receiver
Receiver vocabulary
Act Concept
See the Oracle Healthcare Data Repository Implementation and System Administrator Guide for more information on configuring IMP and OMP.
Use the MTK Services
This section lists details of services that help to test custom Message Types and setup custom Message Types, along with code samples. For more information on MTK Services, refer to Oracle Healthcare Data Repository Javadoc.
Test Custom Message Types
To test a custom Message Type, perform the following steps:
- Initialize the
ServiceLocator. - Create
MtkTestService. - Invoke the
testCustomMessageType()method ofMtkTestService.
If the Message Type testing is successful, the method returns an unique Test
Id. If the testing is not successful, the method throws CTBException and
the Test Id can be obtained from TEST_ID parameter of the CTBException
instance. The files submitted for testing as well the ones generated by MTK will be loaded
in a folder with the test ID name.
The following table summarizes the service and methods referenced by this section:
Service and Methods: Testing Message Type
Level |
Detail |
Package |
Class |
Methods |
(oracle.apps.ctb.message.mtk.MtkTestService)
Example 9-9 Use the MTKTestService API
//Initializing Service Locator:
ServiceLocator serviceLocator = ServiceLocator.getInstance();
serviceLocator.login("username", "password");
//Payload Xsd and Mif
String payloadXsdName = {“prpa_mt203000ht04.xsd"};
String payloadMifName = {“prpa_mt203000ht04.mif"};
//Cmet Xsds and Mifs, referred by the Payload.
String [] cmetXsdNames = { “coct_mt030202ht04.xsd",
“coct_mt030200ht04.xsd", “coct_mt150002ht02.xsd",
“coct_mt150000ht04.xsd", “coct_mt030202ht04.xsd"};
String [] cmetMifNames = { “coct_mt030202ht04.mif",
“coct_mt030200ht04.mif", “coct_mt150002ht02.mif",
“coct_mt150000ht04.mif", “coct_mt030202ht04.mif"};
//CoreMif name.
String coreMifName ="cmetinfo.coremif";
//Initializing SchemaInformation
SchemaInformation [] schemaInfo = new SchemaInformation [7];
//Populating SchemaInformation List with values.
for(int i=0; i< cmetXsdNames.length; i++)
String xsdContent = readFileContent(cmetXsdNames[i]);
String mifContent = readFileContent(cmetMifNames[i]);
String artifactID = cmetXsdNames[i].replaceAll(“.xsd", “");
schemaInfo[i] = new SchemaInformation();
schemaInfo[i].setXsd(xsdContent);
schemaInfo[i].setMif(mifContent);
schemaInfo[i].setSchemaType(SchemaInformation.CMET);
schemaInfo.setArtifactID(artifactID);
//Populating payload.
String xsdContent = readFileContent(payloadXsdName);
String mifContent = readFileContent(payloadMifName);
String artifactID = payloadXsdName.replaceAll(“.xsd",“");
schemaInfo[i].setSchemaType(SchemaInformation.PAYLOAD);
//Populating CoreMif.
i++;
String coreMifContent = readFileContent(coreMifName);
schemaInfo[i].setMif(coreMifContent);
schemaInfo[i].setSchemaType(SchemaInformation.CORE_MIF);
schemaInfo[i]. setArtifactID(coreMifName);
String testDesc = “PRPA_MT203000HT04 - Message Type testing on 16-Jan-2008.";
boolean generateReport = true;
String testID = null;
MtkTestService mtkTestService = null;
//calling MtkTestService#testCustomMessageType()
try
mtkTestService = serviceLocator.getMtkTestService();
testID =
mtkTestService.testCustomMessageType(schemaInfo,testDesc,
generateReport);
catch(CTBException ctbException)
//Incase of CTBException, the TEST_ID can be retrieved from
// CTBException instance.
testID = (String)ctbException.getParameter(“TEST_ID");
}Example 9-10 Searching for Test ID
//search key
String searchKey = “%PRTS%MT%";
String [] matchingTestIDs = null;
//invoke getMatchingTestIDs() API.
try
matchingTestIDs = mtkTestService.getMatchingTestIDs(searchKey);
//handle or re-throw the exception
} Example 9-11 Downloading Test ID Files
// Input Test ID
String testID = “PRTS_MT000008TK01_611521202";
TestIDData testIDData = null;
//Invoke downloadTestFilesForATest() API
try
testIDData = mtkTestService.downloadTestFilesForATest(testID);
//retrieving data from TestID object
String messageTypeID = testIDData.getPayloadID();
String masterCatalogReportContent = testIDData.getMasterCatalogReport();
String sIDeEffectReportContent = testIDData. getSIDeEffectReport();
String actConceptReportContent = testIDData.getAmbiguousComplexTypeReport();
String userComments = testtIDData.getUserComment();
TestMessage[] testMessage = testIDData.getTestMessage();
for (int i = 0; i < testMessage.length; i++)
String testMessage = testMessage[i].getTestMessage();
String generatedMessage = testMessage[i].getGeneratedMessage();
SchemaInformation[] schemaInfo = testIDData.getSchemaInformation();Example 9-12 Deleting Test ID Files
//Input Test ID
//Invoke removeTestFilesForATest() API
try
mtkTestService. removeTestFilesForATest(testID);
}Setting Up a New Message Type
To load and manage the successfully tested new Message Types onto a new environment,
- Initialize ServiceLocator.
- Create
MtkProductionLoadService.
Service and Methods: Setting Up a New Message Type
Level |
Detail |
Package |
Class |
Methods |
(oracle.apps.ctb.message.mtk.MtkProductionLoadService)
Example 9-13 Search for Message Types
//Message Type ID
String [] messageTypeID= { “PRPA_MT203000HT04"};
SchemaInformation [] schemaInfo = null;
try
//Getting MtkProductionLoadService
mtkProductionLoadService = serviceLocator.getMtkProductionLoadService();
//Calling fetch API
schemaInfo = mtkProductionLoadService.fetchSchemas (messageTypeID) ;
//…handle or re-throw the exception
if (schemaInfo.length == 0 ) // If Message Type not already uploaded.
//…Invoke loadCustomMessageTypeToProductionServer() API
Example 9-14 Loading Custom Message Types
//Cmet Xsd and Mif, referred by the Payload.
String [] cmetXsdNames = { “coct_mt030202ht04.xsd", “coct_mt030200ht04.xsd", “coct_mt150002ht02.xsd", “coct_mt150000ht04.xsd", “coct_mt030202ht04.xsd"};
String [] cmetMifNames = { “coct_mt030202ht04.mif", “coct_mt030200ht04.mif", “coct_mt150002ht02.mif", “coct_mt150000ht04.mif", “coct_mt030202ht04.mif"};
//CoreMif name.
// Populating CoreMif.
i++;
MtkProductionLoadService mtkProductionLoadService = null;
try
mtkProductionLoadService = serviceLocator. getMtkProductionLoadService();
//Calling upload API
mtkProductionLoadService.loadCustomMessageTypeToProductionServer(schemaInfo);
Example 9-15 Fetch Custom CMETs
String messageTypeID= "POXX_MT111000HT02";
try
//Calling fetch API
schemaInfo = mtkProductionLoadService. FetchCustomCMETsForPayload
(messageTypeID) ;
//…handle and re-throw the exception
Example 9-16 Fetch Composite Message Schema
try
//Calling fetch API
schemaInfo = mtkProductionLoadService. FetchCompositeMessageShemasByPayload
(messageTypeID) ;
SchemaInformation object will not contain MIF content for an Interaction Schema.Example 9-17 Deleting a Schema
String [] schemas = { "coct_mt930002ht03.xsd", "poxx_mt111000ht02.xsd"};
try
//Calling delete API
mtkProductionLoadService. deleteSchemas (schemas) ;
//…handle or re-throw exception
Sample Exercise Using MTK Services
Prerequisites and Tools
Creating a New Message Type or Modifying an Existing Message Type
Generating Schema (XSD) and MIF Files for the Modified Messages
The following tools are used in the process of testing a custom message and generating message instances for the custom messages.
Microsoft® Visio 2002 SP - 2 version 10.0.6871
HL7 RIM repository version 2.14.1
HL7 RMIM Designer version 4.3.2
HL7 Schema Generator version 3.0.4
The steps described in the following sections were performed using the tools listed above, and may not produce expected results if executed using versions other than those specified above.
For the purpose of this sample exercise, a modified version of the HDR-published domain Message Type Person Registry (PRPA_RM201000HT03) and a modified version of the HDR-published CMET E_Person (COCT_RM030202HT04) are used.
- Use the RMIM Designer to modify the CMET E_Person (COCT_RM030202HT04) as follows:
- In the focal class Person, add an attribute educationLevelCode: CE CWE [0..1] < EducationLevel
- Change the name of the CMET to E_Person_Custom and the CMET
code ID to COCT_RM030202TK01
Figure 9-6
- Validate and save the Visio file as COCT_RM030202TK01.vsd. When you save the Visio file, the RMIM designer will automatically create the COCT_RM030202TK01.xml file.
- In the CMETInfo.txt file that is referred by RMIM designer, include an entry for
the custom CMET as follows:
E_Person_Custom,COCT_MT030202TK01,PSN,Entity,Custom Person CMET for testing MTK,identified/confirmable. - Modify the message domain Person Registry (PRPA_RM201000HT03) as follows:
- In the class Employment (Person => Employment), add the
following attributes:
salaryTypeCode: CE CWE [0..1] < EmployeeSalaryTypesalaryQuantity: MO [0..1]
- Replace all references to the
CMET E_Person (PSN) [identified/confirmable] (COCT_MT030202HT04)withE_Person_Custom (PSN) [identified/confirmable] (COCT_MT030202TK01). - Change the name of the RMIM to Person Registry Custom
and the RMIM IDcode to PRPA_RM201000TK01.
Figure 9-7 Custom Message Person_Registry_Custom (PRPA_RM201000TK01)
- Validate and save the Visio file as ‘PRPA_RM201000TK01.vsd'.
- Verify that Visio automatically generates a file ‘PRPA_RM201000TK01.xml'.
Generate Schema (XSD) and MIF Files for the Modified Messages
Use the Schema Generator generate schema and MIF files for the modified messages as follows:
Generate Test Messages Using MTK Service
Refer to the Use the MTK Services section to test the newly created message type artifacts and retrieve the test messages generated by MTK test API.
Generating Custom Message Types
You can create custom artifacts either by using RMIM or by using the artifacts published by HL7. Ensure that you give valid names for the custom messages. You must ensure that:
Realm code in the artifact ID must be other than HT.
CMET names must be different from the Oracle-published CMET names.
Oracle will not provide tools to design artifacts and its associated files. You have to use the tools provided by HL7 or create your own tools.
The tools used to generate schema must also generate MIF files.
HL7 RMIM Designer v4.3.2
RoseTree v4.0.12
HL7 Schema Generator v3.0.4
Generating Custom Artifacts Using RMIM
RMIMs can be created in one of the following ways:
Modifying the RMIM of the Oracle-published Message Types.
Downloading and modifying the RMIM of the HL7-published normative Message Types.
Creating a new RMIM for a Message Type RMIM.
Once the RMIMs are created, save the RMIM in a repository. Provide the XML of the RMIM as input to the tools generating the Schema.
Logic for Instance Generation
MTK uses the following logic to generate a test instance:
Custom Message Types and CMETs are filled with default data even if they are optional items.
CMETs that are mandatory are filled with data irrespective of whether they are Oracle published or custom CMETs.
Items (Classes, CMETs, and Attributes) in custom artifacts (Message Type, CMETs) are handled using the following logic:
Mandatory Items
Classes and CMETs with {1..1, 1..N, and 1..*} cardinality are filled only once.
Recursions with {1..1, 1..N, and 1..*} cardinality are filled once and only one level is filled.
Coded Attributes with {1..1, 1..N, and 1..*} cardinality are filled only once.
Non-coded attributes with {1..1} cardinality are filled only once.
Non-coded attributes with {1..N and 1..*} cardinality are filled twice.
Choices with 0..* or 1..* are repeated as many number of times as the number of objects in the choice to fill all the objects within the choice.
Optional Items
Classes and CMETs with {0..1, 0..N, and 0..*}, cardinality are filled once.
Recursions with {0..1, 0..N, and 0..*} cardinality are filled once and only one level is filled.
Attributes (Coded and Non-Coded) with {0..1, 0..N, and 0..*} cardinality are not filled.
Choices with {0..1, 0..N, and 0..*}cardinality are filled only once.
Items (Classes, CMETs, and Attributes) relating to Oracle-published CMETs are handled using the following logic:
Mandatory Items
Classes and CMETs with {1..1, 1..N, and 1..*}, cardinality are filled only once.
Within the mandatory CMETs, only mandatory classes with {1..1, 1..N, and 1..*} cardinality are filled with data, and only the attributes with {1..1, 1..N, and 1..*}cardinality are populated with data.
Choices with {1..1, 1..N, and 1..*}cardinality are filled only once.
Optional items
Classes and CMETs with {0..1, 0..N, and 0..*} cardinality are not filled.
Recursions with {0..1, 0..N, and 0..*} cardinality are not filled.
Choices with {0..1, 0..N, and 0..*} cardinality are not filled.
Data for Clone class attributes are populated using the following logic:
Data for the structural attributes is populated from the respective schema.
A unique test ID is assigned for each clone class object.
For coded attributes bound to concept lists, data is taken from the respective concept list within ETS and populated. Note that if the concept list is empty, an error is thrown
For coded attributes not bound to concept lists, a value from the appropriate HL7 coding scheme is populated based on their types (For example, code attribute of Act class has code from
ActCodeCode System) -
Non-Coded attributes like address, name, and others are populated with data from the sample snippets seeded in HDR.
Attributes with Any datatype are defaulted to ST and a default value is populated.
Message Wrapper and Control Act wrapper:
Data for the Message wrapper, Act Payload Control wrapper, and Role Payload Control wrapper is seeded in HDR.
The Interaction ID, Trigger event code, and Sender and Receiver II attribute values are generated during each instance generation.
The objective of instance generation is to cover all the objects of custom artifacts (Message Type and CMETs) irrespective of whether they are optional or not.
Within an instance, if the object of external artifact is covered once, the same object is not repeated unless it is mandatory.
External artifacts with Roles having entity choices either as Player or Scoper will always result in more than one instance. Each of the Player/Scoper choice is included in one of the instances.
The order of the objects in the instance generated depend on their order in the schema file.
Master Catalog and Side Effect Configuration Reports
Master Catalog Reports
This section details the validation logic followed by MTK for Master Catalog validations, and also the logic used to generate the Master Catalog report.
Master Catalog Validation Rules
MTK follows the rules listed below to validate the schema against the Master Catalog entries to verify if the entries exist:
General Rules
- If the object in the schema has a code attribute,
If the code attribute is mandatory in the schema, MTK checks if an entry for that object exists in the Master Catalog (MC) configuration with Code Type as ANY. If it is not present, MTK includes that object in the MC Report.
If the code attribute is optional in the schema, MTK checks if an entry for that object exists in the MC Configuration with Code Type as ANY. If it does not exist, MTK includes that object in the MC Report. In addition, MTK also checks if an entry exists for that object in the MC Configuration with Code Type as NULL. It it does not exist, MTK includes that object in the MC Report.
If the object in the schema does not have a code attribute, MTK checks if an entry for that object exists in the MC Configuration with Code Type as NULL. If it is not present, MTK includes that object in the MC Report.
Role: Non-owned Role without Entities
The general rules apply to all objects in the schema that are Non-owned Roles without Entities.
Role: Non-owned Role with Entities
In addition to the general rules, MTK also checks if the corresponding Entity entry exists for the Non-owned Role in the MC configuration. The general rules apply for checking an individual Entity entry in the MC Configuration. If the entry does not exist, MTK includes that object in the MC Report.
ROLE: Owned Role without Non-Owning Entity
For Owned Role, in addition to the general rules, MTK also checks if the corresponding Owning Entity entry exists for the Owned Role in the MC Configuration. The general rules apply for checking an individual Entity entry in the MC configuration. If the entry does not exist, MTK includes all the corresponding objects (both missing role and the missing entities) in the MC Report.
ROLE: Owned Role with Non-Owning Entity
For Owned Role, in addition to the general rules, MTK also checks if the corresponding Owning and Non-Owning Entity for the Owned Role has appropriate entries in the MC Configuration. The general rules apply for checking an individual Entity entry in the MC Configuration. If the entry does not exist, MTK includes all corresponding objects (both missing role and the missing entities) in the MC Report.
In case of Owned Roles, MTK also checks if the entry in the ROLE_OWNER_CODE (in the MC Configuration) has P or S, depending on whether the Owning Entity is a Player or a Scoper. If the entry does not exist, MTK includes that object in the MC Report.
Master Catalog Reporting Logic
MTK populates a report based on the rules described in the Master Catalog Validation Rules section, and then based on the value in the Report column (Yes or No). If the Report column contains the value Yes, the following logic is applied while creating an entry in the Master Catalog report:
Act
With mandatory code attribute: Create an entry with code type ANY.
With optional code attribute: Create entries with code type ANY and Null.
Without code attribute: Create an entry with code type Null.
Non-Owned Role with Entities
With mandatory code attribute: Create an entry with code type ANY, and with appropriate Entity entries.
With optional code attribute: Create entries with code type ANY and Null, and with appropriate Entity entries.
Without code attribute: Create an entry with code type Null, and with appropriate Entity entries.
Non-Owned Role without Entities
With mandatory code attribute: Create an entry with code type ANY, and without any entities.
With optional code attribute: Create entries with code type ANY and Null, and without any entities.
Without code attribute: Create an entry with code type Null, and without any entities.
Owned Role with non-owning Entity
With mandatory code attribute: Create an entry with code type ANY, and with appropriate non-owning Entity entry.
With optional code attribute: Create entries with code type ANY and Null, and with appropriate non-owning Entity entry.
Without code attribute: Create an entry with code type Null, and with appropriate non-owning Entity entry.
Entity
MTK applies the following rules while creating the Side Effect Configuration report:
Act: Create or Overlay
Non-Owned Role without Entities: Create or Overlay.
Non-Owned Role with Entities: Create or Overlay for both Role and its entities.
Owned Role without non-owning Entity: No entry.
Owned (Type II) Role with non-owning Entity: Null for Role and owning Entity. Create or Overlay for non-owning Entity.
MTK Message Types Construct Processing
Constructs in External Artifacts (Message Type and CMETS)
Constructs Within Oracle Published CMETS
The order of the objects in the instance generated depend on their order in the schema file. The objects listed in the examples might change when compared to actual instances.
Constructs in External Artifacts (Message Type and CMETs)
Act> ActChoice with {0..1 or 1..1 or 0..n or 1..n}
MTK generates n instances where n is the number of objects in the choice (and is not same as *). MTK generates two instances if a message type that has the construct described in Figure E.1. For each object within the choice, a message instance is generated.
- First message instance has ClinicalTrialEvent > inFulfillmentOf > ObservationEvent
- Second message instance has ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent
Figure 9-8 Act > ActChoice with {1..1}
Act> ActChoice with {0..* or 1..*}
MTK generates one instance with two inFulfillmentOf ActRelationship, if a message type has the construct shown in Figure E.2. For each object within the choice, an inFulfillmentOf ActRelationship is generated.
- First instance of inFulfillmentOf ActRelationship would have ClinicalTrialEvent > inFulfillmentOf > ObservationEvent
- Second instance of inFulfillmentOf ActRelationship would have ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent
Figure 9-9 Act > ActChoice with {1..*}
Act> ActChoice with {0..1 or 1..1 or 0..n or 1..n}> Act with {0..1 or 1..1 or 0..n or 1..n or 0..* or 1..*}
MTK generate n instances where n is the number of objects in the first choice. MTK generate two instances if a message type has the construct described in Figure E.3. For each object within the choice, a message instance is generated along with the target pertinentInformation ActRelationship.
- First message instance has ClinicalTrialEvent > inFulfillmentOf > ObservationEvent > pertinentInformation > ObservationInfo
- Second message instance has ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent > pertinentInformation > ObservationInfo
Figure 9-10 Act > Choice with {1..1} > Act with {1..1}
Act > ActChoice with {0..* or 1..*} > Act with {0..1 or 0..* or 0..n or 1..n or 1..1 or 1..*}
MTK generates one instance with two inFulfillmentOf ActRelationship, if a message type has the construct described in Figure E.4. For each object within the choice, an inFulfillmentOf ActRelationship is generated along with one target pertinentInformation ActRelationtionship.
- First instance of inFulfillmentOf ActRelationship has ClinicalTrialEvent > inFulfillmentOf > ObservationEvent > pertinentInformation > ObservationInfo
- Second instance of inFulfillmentOf ActRelationship has ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent > pertinentInformation > ObservationInfo
Figure 9-11 Act > ActChoice with {1..*} > Act with {1..1}
Act > ActChoice with {0..1 or 1..1 or 0..n or 1..n} > ActChoice with {0..1 or 1..1 or 0..n or 1..n}
MTK generates n instances where n is the number of objects in the first choice. MTK generates two instance if a message type has the construct described in Figure E.5. For each object within the fulfillmentActChoice, a message instance is generated along with an object from target pertinentActChoice.
- Second message instance has ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent > pertinentInformation > ProcedureInfo
Figure 9-12 Act > ActChoice with {1..*} > ActChoice with {1..1}
Act > ActChoice with {0..* or 1..*} > ActChoice with {0..1 or 1..1 or 0..n or 1..n}
MTK generate one instance with two inFulfillmentOf ActRelationship, if a message type has the construct described in Figure E.6. For each object within the choice, an inFulfillmentOf ActRelationship is generated along with an object from the target choice.
- Second instance of inFulfillmentOf ActRelationship has ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent > pertinentInformation > ProcedureInfo
Figure 9-13 Act > ActChoice with {1..*} > ActChoice with {1..1}
Act > ActChoice with {0..1 or 1..1 or 0..n or 1..n} > ActChoice with {0..* or 1..*}:
MTK generates n instances where n= number of objects is in the first choice. MTK generates two instance if a message type has the construct described in Figure E.7. For each object within the inFulfillmentOf, a message instance is generated along with two pertinentInformation ActRelationships.
ObservationEvent:
- pertinentInformation > ObservationInfo
- pertinentInformation > ProcedureInfo
ProcedureEvent:
Figure 9-14 Act > Choice with {1..1} > ActChoice with {1..*}
Act > ActChoice with {0..* or 1..*} > ActChoice with {0..*}
MTK generates one instance with two inFulfillmentOf ActRelationship, if a message type has the construct described in Figure E.8. The first inFulfillmentOf ActRelationship instance has the objects from the target pertinentActChoice. The other inFulfillmentOf ActRelationship instance does not have it.
inFulfillmentOf > ObservationEvent:
- Second instance of fulfillmentActChoice ActRelationship has ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent
Figure 9-15 Act > ActChoice with {1..*} > ActChoice with {0..*}
Act > ActChoice with {0..* or 1..*} > ActChoice with {1..n or 1..*}
MTK generates one instance with two inFulfillmentOf ActRelationship, if a message type has the construct described in Figure E.9. For each object within FullfillmentActChoice, a inFulfillmentOf ActRelationship is generated along with the object from the target pertinentActChoice.
inFulfillmentOf > ProcedureEvent (one of the below):
Figure 9-16 Act > ActChoice with {1..*} > ActChoice with {1..*}
Act > Role with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*} > Player with {0..1 or 1..1} and Scoper with {0..1 or 1..1}
MTK generates only one instance if a message type has the construct described in Figure E.10. The message instance has:
- Message Instance: ObservationGeneral > subject > IdentifiedEntity > ScopingEntity and PlayingEntity
Figure 9-17 Act > Role with {0..*} > Player with {0..1} and Scoper with {1..1}
Act > Role with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*} > Player with {0..1 or 1..1} and Scoper with {0..1 or 1..1} > Playedrole with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*} > Scoper with {0..1 or 1..1}
MTK generates only one instance if a message type has the construct described in Figure E.11. The instance generated has the following:
- Message instance: ObservationGeneral > subject > IdentifiedEntity >
ScopingEntity and Playingentity<
- PlayingEntity > HealthChart > ScopingEntity2
Figure 9-18 Act > Role with {0..*} > Player with {0..1} and Scoper with {1..1} > Playedrole with {0..*} > Scoper with {0..1}
Act > Role with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*} > PlayerChoice with {0..1 or 1..1} and ScoperChoice with {0..1 or 1..1} > PlayedRole with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*} > Scoper with {0..1 or 1..1}
MTK generates n instances where n is the maximum number of entities present in a single choice. In the construct described in Figure E.12, MTK generates two instances. The instances generated might be:
- First Instance: ObservationGeneral > subject > IdentifiedEntity >
- Playingentity > HealthChart > ScopingEntity2
- Second Instance: ObservationGeneral > subject > IdentifiedEntity >
Organization and Person
- Person > HealthChart > ScopingEntity2
Figure 9-19 Act > Role with {0..*} > PlayerChoice with {0..1} and ScoperChoice with {1..1} > Playedrole with {0..*} > Scoper with {0..1}
Even if the cardinality of participation is 0..*, MTK generates multiple instances of the above structure to incorporate all the entities. This behavior is different from ActRelationships.Act> Role with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*}> PlayerChoice with {0..1} and ScoperChoice with {0..1 or 1..1}> PlayedRole with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*}> Scoper with {0..1 or 1..1}
MTK generates n instances where n is the number of entities in the choice with Max entities. In the construct described in Figure E.13, MTK generates three instances:
- Instances with player entities has the Owned role
- One of the instances has only the scoper for IdentifiedEntity role. This instance does not have any Player as (i) the cardinality is 0..1 (ii) both the player entities would have been covered in the previous two messages.
The instance generated might be:
- First Instance: ObservationGeneral > subject > IdentifiedEntity > Entity
and Person
- Second Instance : ObservationGeneral > subject > IdentifiedEntity >
Organization and Entity
- Entity > HealthChart > ScopingEntity2
- Third Instance : ObservationGeneral > subject > IdentifiedEntity > Place
Figure 9-20 Act > Role with {0..*} > PlayerChoice with {0..1} and ScoperChoice with {1..1} > Playedrole with {0..*} > Scoper with {0..1}
Act> Role with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*}> PlayerChoice with {1..1} and ScoperChoice with {0..1 or 1..1}> PlayedRole with {0..1 or 0..n or 0..* or 1..1 or 1..n or 1..*}> Scoper with {0..1 or 1..1}
MTK generates n instances where n is the number of entities in the choice with Max entities. In the construct described in Figure E.14, MTK generates three instances. All the three instances have the Owned role due to the cardinality on the PlayerChoice.
and Person
- Third Instance: ObservationGeneral > Subject > IdentifiedEntity > Place
and Person
Figure 9-21 Act > Role with {0..*} > PlayerChoice with {1..1} and ScoperChoice with {0..1} > PlayedRole with {0..*} > Scoper with {0..1}
Act> ActChoice with {1..1 or 1..n or 1..*}
MTK will generate one instance. The generated instance will be one of the following:
- ClinicalTrialEvent > inFulfillmentOf > ObservationEvent
- ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent
If the choice is {0..1 or 0..*}, the generated instance will not have the fulfillmentActChoice ActRelationship.Figure 9-22 Act > ActChoice with {1..1}
Act> ActChoice with {1..1 or 1..n or 1..*}> Act with { 1..1 or 1..n or 1..*}
MTK generates one instance. The instance will have one of the following:
- ClinicalTrialEvent > inFulfillmentOf > ObservationEvent > pertinentInformation > ObservationInfo
- ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent > pertinentInformation > ObservationInfo
- If the inFulfillmentOf has {0..1 or 0..*}, then the generated instance will not have the inFulfillmentOf ActRelationship and the other associated relationships
- If the inFulfillmentOf has {1..1 or 1..*} and observationInfo has {0..1 or 0..*} then the generated instance will have inFulfillmentOf ActRelationship but not the pertinentInformation relationships
Figure 9-23 Act > ActChoice with {1..1} > ActChoice with {1..1}
Act> ActChoice with {1..1 or 1..n or 1..*}> ActChoice with {1..1 or 1..n or 1..*}
MTK generates one instance, if a message type has the construct described in Figure E.17. The generated message instance has one of the following:
- ClinicalTrialEvent > inFulfillmentOf > ProcedureEvent > pertinentInformation > ProcedureInfo
- If the inFulfillmentOf has {0..1 or 0..*}, then the generated instance will not have the inFulfillmentOf ActRelationship and the other associated relationships.
- If the inFulfillmentOf has {1..1 or 1..*} and if pertinentInformation has {0..1 or 0..*} then the generated instance will have inFulfillmentOf ActRelationship but not the pertinentInformation relationships.
Figure 9-24 Act > Role with {1..*} > Player with {1..1} and Scoper with {1..1}
Act > Role with {1..1 or 1..n or 1..*} > PlayerChoice with {1..1} and ScoperChoice with {1..1} > PlayedRole with {1..1 or 1..n or 1..* } > Scoper with {1..1}
In the construct described in Figure E.19, MTK generates one instance. The instance generated might be:
- ObservationGeneral > subject > IdentifiedEntity > ScopingEntity and PlayingEntity
- ObservationGeneral > subject > IdentifiedEntity > Organization and Person
- If the subject has {0..1 or 0..*} then the generated instance will not have the subject and its associated associations.
- If the subject has {1..1 or 1..*} and Scoper and Player choice with {0..1} then the generated instance will have: ObservationGeneral > subject > IdentifiedEntity
- If the subject has {1..1 or 1..*}, Player choice with {1..1} along with HealthChart with {1..1}, and ScoperChoice with {0..1} then the generated instance will have one of the below:
- ObservationGeneral > subject > IdentifiedEntity > PlayinngEntity > HealthChart > ScopingEntity2
- ObservationGeneral > subject > IdentifiedEntity > Person > HealthChart > ScopingEntity2
Figure 9-25 Act > Role with {1..*} > PlayerChoice with {1..1} and ScoperChoice with {1..1} > Playedrole with {1..*} > Scoper with {1..1}
XML Snippets of Seeded Data
Data seeded in HDR for MTK to generate instance for the provided Message Type schema file:
Datatypes |
Value 1 |
Value 2 |
AD |
<[attribute] use="H" > <delimiter partType="DEL">;</delimiter> <country partType="CNT">US</country> <state partType="STA">CA</state> <city partType="CTY">Fountain Hills</city> <postalCode partType="ZIP">85268</postalCode> <streetAddressLine partType="SAL">15542 OliveWest</streetAddressLine> <houseNumberNumeric partType="BNN" >999777</houseNumberNumeric> <houseNumber partType="BNR">999777</houseNumber> <direction partType="DIR">N</direction> <streetName partType="STR">Church Street</streetName> <streetNameBase partType="STB">Church Street</streetNameBase> <streetNameType partType="STTYP">Avenue</streetNameType> <unitID partType="UNID">222222</unitID> <censusTract partType="CEN">testCensusValue</censusTract> <unitType partType="UNIT">Apartment</unitType> <useablePeriod xsi:type="IVL_TS" > <low value="20070127" inclusive="true"/> <high value="20070526" inclusive="false"/> </useablePeriod> </[attribute]> |
<[attribute] use="H"> <delimiter partType="DEL">;</delimiter> <country partType="CNT">US</country> <state partType="STA">CA</state> <city partType="CTY">Fountain Hills</city> <postalCode partType="ZIP">852</postalCode> <streetAddressLine partType="SAL">142 OliveWest</streetAddressLine> <houseNumberNumeric partType="BNN" >9977</houseNumberNumeric> <houseNumber partType="BNR">9997</houseNumber> <direction partType="DIR">N</direction> <streetName partType="STR">Church Street</streetName> <streetNameBase partType="STB">Church Street</streetNameBase> <streetNameType partType="STTYP">Avenue</streetNameType> <unitID partType="UNID">222234</unitID> <censusTract partType="CEN">testCensusValue</censusTract> <unitType partType="UNIT">Apartment</unitType> <useablePeriod xsi:type="IVL_TS" > <low value="20070128" inclusive="true"/> <high value="20070527" inclusive="false"/> </useablePeriod> </[attribute]> |
ANY |
<[attribute] xsi:type="ST">MTK Test1</[attribute]> |
<[attribute] xsi:type="ST">MTK Test2</[attribute]> |
BL |
<[attribute] value="true"/> |
<[attribute] value="false"/> |
BN |
ControlActWrapper |
<controlActProcess classCode="CACT" moodCode="EVN"> <subject typeCode="SUBJ"></subject></controlActProcess> |
<controlActProcess classCode="CACT" moodCode="EVN"> <subject typeCode="SUBJ"> <registrationEvent classCode="REG" moodCode="EVN"> <code code="T" codeSystemName="ActCode"/> <subject typeCode="SBJ"> </subject> </registrationEvent> </subject> </controlActProcess> |
ED |
<[attribute] mediaType="text/plain" language="en-US"> <reference value="http://example.org/xrays/128s8d9ej229se32s.png"> <useablePeriod xsi:type="IVL_TS"> <low value="200007200845"/> <high value="200008200845"/> </useablePeriod> </reference>ED.Text1 </[attribute]> |
<[attribute] mediaType="text/plain" language="en-US">ED.Text2 <reference value="http://example.org/xrays/128s8d9ej229se32s.png"> <useablePeriod xsi:type="IVL_TS"> <low value="200007200846"/> <high value="200008200846"/> </useablePeriod> </reference>ED.Text2 </[attribute]> |
EIVL |
<[attribute] xsi:type="EIVL_TS"> <event code="AC" codeSystem="2.16.840.1.113883.5.139" codeSystemName="TimingEvent"/> <offset> <low value="10" unit="h"/> <high value="20" unit="h"/> </offset> </[attribute]> |
<[attribute] xsi:type="EIVL_TS"> <event code="ACD" codeSystem="2.16.840.1.113883.5.139" codeSystemName="TimingEvent"/> <offset> <low value="11" unit="h"/> <high value="21" unit="h"/> </offset> </[attribute]> |
EN |
<[attribute] use="L"> <family partType="FAM">John</family> <given partType="GIV">Doe</given> <validTime xsi:type="IVL_TS"> <low value="20070127" inclusive="true"/> <high value="20070526" inclusive="false"/> </validTime> </[attribute]> |
<[attribute] use="L"> <family partType="FAM">John</family> <given partType="GIV">Doe</given> <validTime xsi:type="IVL_TS"> <low value="20070129" inclusive="true"/> <high value="20070529" inclusive="false"/> </validTime> </[attribute]> |
II |
<[attribute] root="9.989898.5.100.10" extension="MTK1" assigningAuthorityName="ORACLE"/> |
INT |
<[attribute] xsi:type="INT" value="204" /> |
<[attribute] xsi:type="INT" value="205" /> |
IVL_INT |
<[attribute] xsi:type="IVL_INT"> <low value="10"/> <high value="20"/> </[attribute]> |
IVL_MO |
<[attribute] xsi:type="IVL_MO"> <low value="200" currency="USD"/> <width value="205" currency="USD"/> </[attribute]> |
<[attribute] xsi:type="IVL_MO"> <low value="1000" currency="USD"/> <width value="2000" currency="USD" /> </[attribute]> |
IVL_PQ |
<[attribute] xsi:type="IVL_PQ"> <low value="10" unit="g"/> <high value="20" unit="g"/> </[attribute]> |
<[attribute] xsi:type="IVL_PQ"> <low value="1100" unit="g"/> <high value="2200" unit="g"/> </[attribute]> |
IVL_REAL |
<[attribute] xsi:type="IVL_REAL"> <low value="10.05"/> <high value="20.05"/> </[attribute]> |
<[attribute] xsi:type="IVL_REAL" value="10.05"> |
IVL_TS |
<[attribute] xsi:type="IVL_TS"> <low value="20070127" inclusive="true"/> <high value="20070526" inclusive="false"/> </[attribute]> |
<[attribute] xsi:type="IVL_TS"> <low value="20070127" inclusive="true"/> <width value="2" unit="h"/> </[attribute]> |
MO |
<[attribute] value="204" currency="USD"/> |
<[attribute] value="204" currency="INR"/> |
ON |
<[attribute] use="L"> <prefix partType="PFX">Prime Health</prefix> <suffix partType="SFX">Clinic</suffix> </[attribute]> |
<[attribute] use="L"> <prefix partType="PFX">Prime Health</prefix> <suffix partType="SFX">Speciality Center</suffix> </[attribute]> |
PIVL |
<[attribute] xsi:type="PIVL_TS" alignment="DW" institutionSpecified="false"> <phase> <low value="20070319" inclusive="true"/> <high value="20070324" inclusive="false"/> </phase> <period value="1" unit="wk"/> </[attribute]> |
<[attribute] xsi:type="PIVL_TS" alignment="HD" operator="A"> <phase> <low value="200703190900" inclusive="true"/> <high value="200703191700" inclusive="false"/> </phase> <period value="1" unit="d"/> </[attribute]> |
PN |
<[attribute] use="L"> <family partType="FAM">Levin</family> <given partType="GIV">Henry Jr</given> </[attribute]> |
<[attribute] use="L"> <family partType="FAM" qualifier="VV">Levin</family> <given partType="GIV">Henry Sr</given> </[attribute]> |
PQ |
<[attribute] xsi:type="PQ" value="204" unit="g"/> |
<[attribute] xsi:type="PQ" value="205" unit="g"/> |
REAL |
<[attribute] xsi:type="REAL" value="204" /> |
<[attribute] xsi:type="REAL" value="205" /> |
RTO_INT |
<[attribute] xsi:type="RTO_INT"> <numerator value="204"/> <denominator value="204"/> </[attribute]> |
<[attribute] xsi:type="RTO_INT"> <numerator value="205"/> <denominator value="205"/> </[attribute]> |
RTO_MO_PQ |
<[attribute] xsi:type="RTO_MO_PQ"> <numerator value="204" currency="USD"/> <denominator value="204" unit="g"/> </[attribute]> |
<[attribute] xsi:type="RTO_MO_PQ"> <numerator value="205" currency="USD"/> <denominator value="205" unit="g"/> </[attribute]> |
RTO_PQ |
<[attribute] xsi:type="RTO_PQ_PQ"> <numerator xsi:type="PQ" value="2" unit="g"/> <denominator xsi:type="PQ" value="1" unit="1"/> </[attribute]> |
<[attribute] xsi:type="RTO_PQ_PQ"> <numerator xsi:type="PQ" value="4" unit="g"/> <denominator xsi:type="PQ" value="2" unit="1"/> </[attribute]> |
RTO_PQ_PQ |
RTO_QTY_QTY |
<[attribute] xsi:type="RTO_QTY_QTY"> <numerator xsi:type="PQ" value="2" unit="g"/> <denominator xsi:type="PQ" value="1" unit="1"/> </[attribute]> |
<[attribute] xsi:type="RTO_QTY_QTY"> <numerator xsi:type="PQ" value="4" unit="g"/> <denominator xsi:type="PQ" value="2" unit="1"/> </[attribute]> |
ST |
<[attribute]>MTK Test1</[attribute]> |
<[attribute]>MTK Test2</[attribute]> |
SXCM_TS |
<[attribute] xsi:type="SXPR_TS"> <comp xsi:type="IVL_TS"> <low value="20050603" /> <high value="20050603" /> </comp> <comp xsi:type="PIVL_TS" operator="A" institutionSpecified="true"> <period value="6" unit="h" /> </comp> </[attribute]> |
<[attribute] xsi:type="SXPR_TS"> <comp xsi:type="IVL_TS"> <low value="20050604" /> <high value="20050604" /> </comp> <comp xsi:type="PIVL_TS" operator="A" institutionSpecified="true"> <period value="7" unit="h" /> </comp> </[attribute] |
TEL |
<[attribute] value="tel:1-690-555-1111" use="H" /> |
<[attribute] value="tel:1-690-555-2222" use="WP" /> |
TN |
<[attribute]>Babel Fish</[attribute]> |
<[attribute]>Red Herring</[attribute]> |
TransmissionWrapper |
<MCCI_MT000100HT04.Message xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="urn:hl7-org:v3" xmlns:xsip="urn:hl7-org:v3" xmlns:htb="http://xmlns.oracle.com/apps/ctb/messaging" ITSVersion= "XML_1.0"> <creationTime value="20040719080000-0800"/> <responseModeCode code="C"/> <versionCode code="V3PR1"/> <interactionId root="9.989898.5.100" extension="PRPA_HN400000"/> <profileId root="9.989898.5.1" extension="v2.14.1.01"/> <processingCode code="P"/> <processingModeCode code="T"/> <acceptAckCode code="AL"/> <receiver typeCode= "RCV"> <device classCode="DEV" determinerCode="INSTANCE" > <id root="9.989898.5.100" extension="DEV1000"/> <asAgent classCode="AGNT" > <representedOrganization classCode="ORG" determinerCode="INSTANCE" > <id root="9.989898.5.100" extension="ORG1000"/> </representedOrganization> </asAgent> </device> </receiver> <respondTo typeCode ="RSP"> <device classCode="DEV" determinerCode="INSTANCE" > <id root="9.481456.5.1" extension="DEV1001"/> <asAgent classCode="AGNT" > <representedOrganization classCode="ORG" determinerCode="INSTANCE"> <id root="9.481456.5.1" extension="ORG1001"/> </representedOrganization> </asAgent> </device> </respondTo> <sender typeCode ="SND"> <device classCode="DEV" determinerCode="INSTANCE" > <id root="9.481456.5.6" extension="MTKTest"/> <asAgent classCode="AGNT" > <representedOrganization classCode="ORG" determinerCode="INSTANCE"> <id root="9.481456.5.1" extension="ORG1001"/> </representedOrganization> </asAgent> </device> </sender> </MCCI_MT000100HT04.Message> |
TS |
<[attribute] value="20070719080000-0800" /> |
<[attribute] value="20070719080000-0801" /> |
URL |
<[attribute] value="www.Oracle.com"/> |
<[attribute] value="http://www.hl7.org/"/> |
Expected Differences in Instances
Extra Internal ID Elements
The objects in the generated message can contain one extra ID attribute when compared to the corresponding object in the input message. This is not an issue, provided this extra id attribute represents the internal id of the object.
For person and organization entity objects, three IDs are generated and for other elements two IDs are generated.
Tasks:
Example 9-18 Input XML Element
<Person type="Person" classCode="PSN" determinerCode="INSTANCE" htb:association="player"> <id root="9.989898.5.1" extension="PSN9002"/> <name use="L"> <family partType="FAM" encoding="TXT">Mart</family> <given partType="GIV" encoding="TXT">Bob</given> </name> </Person>
Example 9-19 Corresponding Output
<Person type="Person" classCode="PSN" determinerCode="INSTANCE" htb:association="player"> <id root="9.101010.5" extension="23617" displayable="false"/> <id root="9.989898.5.1" extension="PSN9002"/>displayable="false"/> <id root="9.989898.5" extension="5321906" displayable="false"/> <name use="L"><family partType="FAM" encoding="TXT">Mart</family> <given partType="GIV" encoding="TXT">Bob</given> </name> </Person>
Extra XML Attributes in Coded Values
The XML representations of coded values will contain their full complement of attributes in the generated message, even though some of these attributes were absent in the persisted message. This is not an issue.
Tasks:
Example 9-20 Input XML Element
<code code="PORR_TE100001" codeSystemName="HDR Supplemental"/>
Example 9-21 Corresponding Output
<code code="PORR_TE100001" codeSystemName="HDR Supplemental" codeSystem="2.16.840.1.113894.1004.100.100.2.5" codeSystemVersion="HDR Supplemental (2005-02-28)" displayName="Christian: Assembly of God"/>
Order Differences in Collection Attributes
The order of the constituent elements in collection attributes (those of type SET or BAG) may not be preserved in the generated message.
Tasks:
Example 9-22 Input XML Element
<statusCode code = "active"/><telecom value="tel:1-690-555-1111" use="H" /><telecom value="tel:1-690-555-1111" use="WP"/>
Example 9-23 Corresponding Output
<statusCode code = "active"/> <telecom value="tel:1-690-555-1111" use="WP" /> <telecom value="tel:1-690-555-1111" use="H"/>
Order Differences Due to Choice Elements
When a ActRelationship has cardinality greater than one, and the target's type is a choice, then the order of the output elements may not match the order of the input elements.
Tasks:
Example 9-24 Input XML Element
<PORR_MT100001HT01.InvestigationEvent …> … <component typeCode="COMP" > <SubstanceAdministrationEvent classCode="SBADM" moodCode="EVN" negationInd="false""> … </SubstanceAdministrationEvent> </component> <component typeCode="COMP" > <SpecimenObservationEvent classCode="SPCOBS" moodCode="EVN" negationInd="false" > … </SpecimenObservationEvent> </component> <component typeCode="COMP" > <ObservationEventGeneral classCode="OBS" moodCode="EVN" negationInd="false" > … </ObservationEventGeneral> </component> <component typeCode="COMP" > <EncounterEvent classCode="ENC" moodCode="EVN" > … </EncounterEvent> </component> … </PORR_MT100001HT01.InvestigationEvent >
Example 9-25 Corresponding Output
<PORR_MT100001HT01.InvestigationEvent …> … <component typeCode="COMP" > <SpecimenObservationEvent type="Observation" classCode="SPCOBS" moodCode="EVN" negationInd="false" > … </SpecimenObservationEvent> </component> <component typeCode="COMP" > <SubstanceAdministrationEvent classCode="SBADM" moodCode="EVN" negationInd="false" > … </SubstanceAdministrationEvent> </component> <component typeCode="COMP" > <EncounterEvent classCode="ENC" moodCode="EVN" > … </EncounterEvent> </component> <component typeCode="COMP" > <ObservationEventGeneral type="Observation" classCode="OBS" moodCode="EVN" negationInd="false" > … </ObservationEventGeneral> </component> … </PORR_MT100001HT01.InvestigationEvent >
Differences in the Order of XML Attributes
The order of XML attributes of an element may be different in the input and output messages. The order of the attributes of an XML element is not significant.
Tasks:
Example 9-26 Input XML Element
<telecom value="tel:1-490-555-2222" use="H"/> <POXX_MT121000HT02.SpecimenObservationOrder moodCode="RQO" classCode="SPCOBS" negationInd="false" >
Example 9-27 Corresponding Output
<telecom use="H" value="tel:1-490-555-2222"/> <POXX_MT121000HT02.SpecimenObservationOrder classCode="SPCOBS" moodCode="RQO" negationInd="false">
Differences Due to Time Zones
A generated message may contain different literal values for time values than is present in the input message, as the generated time values are represented in the time zone of the database.
Example 9-28 Input XML Element
<id root="9.481456.5.30" extension="NC001"/> <creationTime value="20040719080000-0800"/> <versionCode code="V3PR1"/> <profileId root="9.989898.5.1" extension=" v2.14.1.01"/> <processingCode code="P"/>
Example 9-29 Corresponding Output
<id root="9.481456.5.30" extension="NC001"/> <creationTime value="20070719080000-0800"/> <versionCode code="V3PR1"/> <profileId root="9.989898.5.1" extension=" v2.14.1.01"/> <processingCode code="P"/>
Differences Due to Vocabulary Configuration
OMP can be configured to translate coded attributes before sending them out. In such cases, the input and output values for the coded attribute will be different.
Tasks:
Example 9-30 Input XML Element
<raceCode code="15754" codeSystemName="HL7"/>
Example 9-31 Corresponding Output
<raceCode code="15643001 " codeSystemName="SNOMED-CT" codeSystem="2.16.840.1.113883.6.96 " codeSystemVersion="2.01.4" displayName="White"/>
Differences in the Message Wrapper
Message wrapper of the input message is not persisted by inbound message processor. So, Outbound Message Processor will not generate the same message wrapper again.
MTK generates the test instance by using a seeded message wrapper. This message wrapper is the same for all the test messages. The only difference is the message ids. As outbound message generator does not know what is the content of the inbound message, there will be difference between the following attribute values in both the messages:
Message id
creationTime
responseModeCode
interactionId
acceptAckCode
receiver.device.id
respondTo.device.id
sender.deviceid
receiver. representedOrganization .Id
profileId
Tasks:
Example 9-32 Input XML Element
<MFFI_IN000101 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="urn:hl7-org:v3" xmlns:xsip="urn:hl7-org:v3" xmlns:htb="http://xmlns.oracle.com/apps/ctb/messaging" ITSVersion= "XML_1.0"> <id root = "1.2.3" extension = "158933102"/> <creationTime value="20040719080000-0800"/> <responseModeCode code="C"/> <versionCode code="V3PR1"/> <interactionId root="9.989898.5.100" extension="PRPA_HN400000"/> <processingCode code="P"/> <processingModeCode code="T"/> <acceptAckCode code="AL"/> <receiver typeCode= "RCV"> <device classCode="DEV" determinerCode="INSTANCE" > <id root="9.989898.5.100" extension="DEV1000"/> <asAgent classCode="AGNT" > <representedOrganization classCode="ORG" determinerCode="INSTANCE" > <id root="9.989898.5.100" extension="ORG1000"/> </representedOrganization> </asAgent> </device> </receiver> <respondTo typeCode ="RSP"> <device classCode="DEV" determinerCode="INSTANCE" > <id root="9.481456.5.1" extension="DEV1001"/> <asAgent classCode="AGNT" > <representedOrganization classCode="ORG" determinerCode="INSTANCE"> <id root="9.481456.5.1" extension="ORG1001"/> </representedOrganization> </asAgent> </device> </respondTo> <sender typeCode ="SND"> <device classCode="DEV" determinerCode="INSTANCE" > <id root="9.481456.5.6" extension="MTKTest"/> <asAgent classCode="AGNT" > <representedOrganization classCode="ORG" determinerCode="INSTANCE"> <id root="9.481456.5.1" extension="ORG1001"/> </representedOrganization> </asAgent> </device> </sender> ---------------
Example 9-33 Output XML Element
< MFFI_IN000101 xmlns="urn:hl7-org:v3" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsip="urn:hl7-org:v3" xmlns:htb="http://xmlns.oracle.com/apps/ctb/messaging" ITSVersion="XML_1.0">
<id root="9.989898.5" extension="MTKTest"/>
<creationTime value="20071129155115-0800"/>
<responseModeCode code="D"/>
<interactionId root="9.989898.5" extension="MFPM_IN010000"/>
<profileId root="9.989898.5" extension="2.14.1.01"/>
<acceptAckCode code="NE"/>
<receiver typeCode="RCV">
<device classCode="DEV" determinerCode="INSTANCE">
<id root="9.989898.5.100" extension="ORG1000" displayable="false"/>
<asAgent classCode="AGNT">
</asAgent>
</device>
</receiver>
<respondTo typeCode="RSP">
<id root="9.989898.5" extension="1"/>
</asAgent>
</device>
</respondTo>
<sender typeCode="SND">
</asAgent>
</device>
</sender>
--------------Sample Test Message and Corresponding Generated Message
Task Examples:
Example 9-34 Input XML Element
</asAgent>
</device>
</receiver>
</asAgent>
</device>
</respondTo>
</asAgent>
</device>
</sender>
<code code = "MFFI_TE000101" codeSystemName = "HDR Supplemental"/>
<employmentStaff classCode="EMP">
<id root = "1.2.3" extension = "158931102"/>
<code code = "DEPEN" codeSystemName = "RoleCode"/>
<addr use="H" ><delimiter partType="DEL">;</delimiter>
</useablePeriod>
</addr>
<addr use="H">
</useablePeriod>
</addr>
<effectiveTime xsi:type="IVL_TS">
<low value="20070127"/>
<high value="20070526"/>
</effectiveTime>
<employeePerson determinerCode="INSTANCE" classCode="PSN">
<id root = "1.2.3" extension = "158931402"/>
<id root = "1.2.3" extension = "158931502"/>
<name use="L">
<family partType="FAM" >Levin</family>
<given partType="GIV" >Henry Jr</given>
</name>
<name use="L">
</name>
<desc mediaType="image/png" language="en-US" compression="GZ" integrityCheck="3454bfb019d0e7d47a253b59cf234bc49a0e0cf8">
</useablePeriod>
</reference>
<thumbnail mediaType="image/jpeg" language="en-US" representation="B64"/>
MNYD83jmMdomSJUEdmde9j44zmMir6edjzMMIjdMDSsWdIJdksIJR3373jeu83
6edjzMMIjdMDSsWdIJdksIJR3373jeu83MNYD83jmMdomSJUEdmde9j44zmMir
omSJUEdmde9j44zmMiromSJUEdmde9j44zmMirdMDSsWdIJdksIJR3373jeu83
4zmMir6edjzMMIjdMDSsWdIJdksIJR3373jeu83==</desc>
<administrativeGenderCode code = "F" codeSystemName = "AdministrativeGender"/>
<birthTime value="20060719080000-0800" />
<deceasedInd value="true"/>
<deceasedTime value="20060719080000-0800" />
<multipleBirthInd value="true"/>
<multipleBirthOrderNumber xsi:type="INT" value="204"/>
<organDonorInd value="true"/>
</useablePeriod>
</addr>
<addr use="H">
</useablePeriod>
</addr>
<maritalStatusCode code = "A" codeSystemName = "MaritalStatus"/>
<disabilityCode code = "1" codeSystemName = "PersonDisabilityType"/>
<livingArrangementCode code = "G" codeSystemName = "LivingArrangement"/>
<religiousAffiliationCode code = "1001" codeSystemName = "ReligiousAffiliation"/>
<raceCode code = "1008-2" codeSystemName = "Race"/>
<ethnicGroupCode code = "2135-2" codeSystemName = "Ethnicity"/>
<languageCommunication>
<languageCode code = "EncounterStatus" codeSystemName = "HDR Supplemental"/>
<modeCode code = "ESGN" codeSystemName = "LanguageAbilityMode"/>
<proficiencyLevelCode code = "E" codeSystemName = "LanguageAbilityProficiency"/>
<preferenceInd value="true"/>
</languageCommunication>
</employeePerson>
<employerOrganization determinerCode="INSTANCE" classCode="ORG">
<id root = "1.2.3" extension = "158931702"/>
<id root = "1.2.3" extension = "158931802"/>
<code code = "NDA17" codeSystemName = "EntityCode"/>
<name use="L">
<prefix partType="PFX" >Prime Health</prefix>
<suffix partType="SFX" >Clinic</suffix>
</name>
<name use="L">
<suffix partType="SFX" >Speciality Center</suffix>
</name>
</useablePeriod>
</reference>
</useablePeriod>
</addr>
<addr use="H">
</useablePeriod></addr>
<standardIndustryClassCode code = "001662" codeSystemName = "HDR Supplemental"/>
<asPartOfWhole classCode="PART">
<id root = "1.2.3" extension = "158932002"/>
<id root = "1.2.3" extension = "158932102"/>
</effectiveTime>
</asPartOfWhole>
<contactParty classCode="CON">
<id root = "1.2.3" extension = "158932302"/>
<id root = "1.2.3" extension = "158932402"/>
<contactPerson determinerCode="INSTANCE" classCode="PSN">
<name use="L">
</name>
<name use="L">
</name>
<asPersonDomain classCode="IDENT">
<id root = "1.2.3" extension = "158932602"/>
</asPersonDomain>
</contactPerson>
</contactParty>
</employerOrganization>
</employmentStaff>
</subject>
</subject>
</MFFI_IN000101>Example 9-35 Output XML Element
<MFPM_IN000101 xmlns="urn:hl7-org:v3" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsip="urn:hl7-org:v3" xmlns:htb="http://xmlns.oracle.com/apps/ctb/messaging" ITSVersion="XML_1.0">
</asAgent>
</device>
</receiver>
</asAgent>
</device>
</respondTo>
</asAgent>
</device>
</sender>
<id root="9.989898.5" extension="158933802" displayable="false"/>
<code code="EncounterStatus" codeSystemName="HDR Supplemental" codeSystem="2.16.840.1.113894.1004.100.100.2.5" codeSystemVersion="HDR Supplemental (2005-07-28)" displayName="EncounterStatus"/>
<id root="9.989898.5" extension="158933702" displayable="false"/>
<code code="T" codeSystemName="ActCode" codeSystem="2.16.840.1.113883.5.4" codeSystemVersion="2.01.4" displayName="tea only"/>
<id root="1.2.3" extension="158931102" displayable="false"/>
<code code="DEPEN" codeSystemName="RoleCode" codeSystem="2.16.840.1.113883.5.111" codeSystemVersion="2.01.4" displayName="DEPEN"/>
<addr use="H">
<delimiter partType="DEL" representation="TXT">;</delimiter>
<country partType="CNT" representation="TXT">US</country>
<state partType="STA" representation="TXT">CA</state>
<city partType="CTY" representation="TXT">Fountain Hills</city>
<postalCode partType="ZIP" representation="TXT">85268</postalCode>
<streetAddressLine partType="SAL" representation="TXT">15542 OliveWest</streetAddressLine>
<houseNumberNumeric partType="BNN" representation="TXT">999777</houseNumberNumeric>
<houseNumber partType="BNR" representation="TXT">999777</houseNumber>
<direction partType="DIR" representation="TXT">N</direction>
<streetName partType="STR" representation="TXT">Church Street</streetName>
<streetNameBase partType="STB" representation="TXT">Church Street</streetNameBase>
<streetNameType partType="STTYP" representation="TXT">Avenue</streetNameType>
<unitID partType="UNID" representation="TXT">222222</unitID>
<censusTract partType="CEN" representation="TXT">testCensusValue</censusTract>
<unitType partType="UNIT" representation="TXT">Apartment</unitType>
</useablePeriod>
</addr>
<addr use="H">
<postalCode partType="ZIP" representation="TXT">852</postalCode>
<streetAddressLine partType="SAL" representation="TXT">142 OliveWest</streetAddressLine>
<houseNumberNumeric partType="BNN" representation="TXT">9977</houseNumberNumeric>
<houseNumber partType="BNR" representation="TXT">9997</houseNumber>
<unitID partType="UNID" representation="TXT">222234</unitID>
</useablePeriod>
</addr>
<telecom use="H" value="tel:1-690-555-1111"/>
<telecom use="WP" value="tel:1-690-555-1111"/>
<statusCode code="active"/>
<high value="20070526" inclusive="true"/>
</effectiveTime>
<employeePerson classCode="PSN" determinerCode="INSTANCE">
<id root="9.101010.5" extension="1086238" displayable="false"/>
<id root="1.2.3" extension="158931502" displayable="false"/>
<id root="1.2.3" extension="158931402" displayable="false"/>
<id root="9.989898.5" extension="158933405" displayable="false"/>
<name use="L">
<family partType="FAM" representation="TXT" qualifier="VV">Levin</family>
<given partType="GIV" representation="TXT">Henry Sr</given>
</name>
<name use="L">
<family partType="FAM" representation="TXT">Levin</family>
<given partType="GIV" representation="TXT">Henry Jr</given>
</name>
<desc mediaType="image/png" compression="GZ" integrityCheck="3454bfb019d0e7d47a253b59cf234bc49a0e0cf8" representation="TXT">MNYD83jmMdomSJUEdmde9j44zmMir6edjzMMIjdMDSsWdIJdksIJR3373jeu83
4zmMir6edjzMMIjdMDSsWdIJdksIJR3373jeu83==<reference value="http://example.org/xrays/128s8d9ej229se32s.png"><useablePeriod xsi:type="IVL_TS"><low value="200007200845" inclusive="true"/><high value="200008200845" inclusive="true"/></useablePeriod></reference><thumbnail mediaType="image/jpeg" representation="B64"></thumbnail></desc>
<administrativeGenderCode code="F" codeSystemName="AdministrativeGender" codeSystem="2.16.840.1.113883.5.1" codeSystemVersion="2.01.4" displayName="Female"/>
<birthTime value="20060719080000-0800"/>
<deceasedTime value="20060719080000-0800"/>
<multipleBirthOrderNumber value="204"/>
<addr use="H">
</useablePeriod>
</addr>
<addr use="H">
</useablePeriod>
</addr>
<maritalStatusCode code="A" codeSystemName="MaritalStatus" codeSystem="2.16.840.1.113883.5.2" codeSystemVersion="2.01.4" displayName="Annulled"/>
<disabilityCode code="1" codeSystemName="PersonDisabilityType" codeSystem="2.16.840.1.113883.5.93" codeSystemVersion="2.01.4" displayName="Vision impaired"/>
<livingArrangementCode code="G" codeSystemName="LivingArrangement" codeSystem="2.16.840.1.113883.5.63" codeSystemVersion="2.01.4" displayName="Group Home"/>
<religiousAffiliationCode code="1001" codeSystemName="ReligiousAffiliation" codeSystem="2.16.840.1.113883.5.1076" codeSystemVersion="2.01.4" displayName="Adventist"/>
<raceCode code="1008-2" codeSystemName="Race" codeSystem="2.16.840.1.113883.5.104" codeSystemVersion="2.01.4" displayName="Algonquian"/>
<ethnicGroupCode code="2135-2" codeSystemName="Ethnicity" codeSystem="2.16.840.1.113883.5.50" codeSystemVersion="2.01.4" displayName="Hispanic or Latino"/>
<languageCode code="EncounterStatus" codeSystemName="HDR Supplemental" codeSystem="2.16.840.1.113894.1004.100.100.2.5" codeSystemVersion="HDR Supplemental (2005-07-28)" displayName="EncounterStatus"/>
<modeCode code="ESGN" codeSystemName="LanguageAbilityMode" codeSystem="2.16.840.1.113883.5.60" codeSystemVersion="2.01.4" displayName="Expressed signed"/>
<proficiencyLevelCode code="E" codeSystemName="LanguageAbilityProficiency" codeSystem="2.16.840.1.113883.5.61" codeSystemVersion="2.01.4" displayName="Excellent"/>
</employeePerson>
<employerOrganization classCode="ORG" determinerCode="INSTANCE">
<id root="1.2.3" extension="158931702" displayable="false"/>
<id root="9.989898.5" extension="158933406" displayable="false"/>
<id root="1.2.3" extension="158931802" displayable="false"/>
<id root="9.101010.5" extension="1086239" displayable="false"/>
<code code="NDA17" codeSystemName="EntityCode" codeSystem="2.16.840.1.113883.5.1060" codeSystemVersion="2.01.4" displayName="NDA17"/>
<name use="L">
<prefix partType="PFX" representation="TXT">Prime Health</prefix>
<suffix partType="SFX" representation="TXT">Clinic</suffix>
</name>
<name use="L">
<suffix partType="SFX" representation="TXT">Speciality Center</suffix>
</name>
<addr use="H">
</useablePeriod>
</addr>
<addr use="H">
</useablePeriod>
</addr>
<standardIndustryClassCode code="001662" codeSystemName="HDR Supplemental" codeSystem="2.16.840.1.113894.1004.100.100.2.5" codeSystemVersion="HDR Supplemental (2005-07-28)" displayName="Snack"/>
<id root="1.2.3" extension="158932002" displayable="false"/>
<id root="1.2.3" extension="158932102" displayable="false"/>
</effectiveTime>
</asPartOfWhole>
<id root="1.2.3" extension="158932302" displayable="false"/>
<id root="1.2.3" extension="158932402" displayable="false"/>
<contactPerson classCode="PSN" determinerCode="INSTANCE">
<name use="L">
</name>
<name use="L">
</name>
<id root="1.2.3" extension="158932602" displayable="false"/>
</asPersonDomain>
</contactPerson>
</contactParty>
</employmentStaff>
</subject>
</subject>
</ MFPM_IN000101 >Error Messages
The & sign in the Error Message column of the above table indicates variable name. MTK displays the value of these variable at runtime.
Error Code |
Exception Type |
Error Message |
Error Description |
CTB_MTK_NO_SCHEMA_INFO |
CTBValidationRuntimeException |
There is no SCHEMA in the list provided to test. Client application has passed a null SCHEMAINFORMATION object. |
This error shows that schemainformation object is not passed to the API .Please create schemainformation object array of xsds and mifs which are to be tested and pass it to the API. |
CTB_MTK_NO_MIF_CONTENT |
The content of the MIF file |
In schemainformation object only MIF file name is set but the content of the file is not set . Please set the MIF file content as well on the schemainformation object. |
CTB_MTK_NO_XSD_CONTENT |
The content of the XSD file |
In schemainformation object only XSD file name is set but the content of the file is not set . Please set the XSD file content as well on the schemainformation object. |
CTB_MTK_NO_MIF_AND_XSD_CONTENT |
Both XSD |
In schemainformation object both XSD and MIF file name is set but the content of the files are not set . Please set the XSD and MIF file content as well on the schemainformation object. |
CTB_MTK_INVALID_SCHEMA_TYPE |
Validation of input parameters failed. SCHEMA INFORMATION TYPE |
SchemaInformation object requires a SCHEMA INFORMATION TYPE parameter to be set which can have following values 1.PAYLOAD 2.CMET 3. COREMIF. If another value other than these 3 values set for SCHEMA INFORMATION TYPE is encountered, this error is thrown . Please use the correct SCHEMA INFORMATION TYPE values in uploaded schemainformation object. |
CTB_MTK_DUPLICATE_XSD |
XSD |
This error shows that the xsd which user is trying to upload is already present as an Oracle supplied artifact . Please change the name of xsd (other than oracle supported ones) and set it on the schemainformation object. |
CTB_MTK_NO_CORE_MIF |
The content of file CMETINFO.COREMIF file is empty. |
MTK throws this error when in the schemainformation object schema_type is set as coremif but the content of the files on the object are null. Please pass the coremif content as well in the schemainformation object. |
CTB_MTK_PAYLOAD_NT_FOUND |
PAYLOAD XSD is not present in the SCHEMA information passed to MESSAGING TOOL KIT. |
MTK throws this error when in the schemainformation object does not contain payload xsd . Please pass the payload xsd information in schemainformation object. |
CTB_MTK_DUPLICATE_PAYLOAD |
More than one PAYLOAD present in the SCHEMA information passed to MESSAGING TOOL KIT. |
MTK throws this error when in the schemainformation object array have more than one payload schemainformation objects . Please upload only one payload in schemainformation object array. |
CTB_MTK_UNSUPPORTED_RIM_CLASS |
CTBRuntimeException |
PAYLOAD CLASS type ' |
If the payload entry point class is not of type ROLE or ACT, this error is thrown. Please use only ROLE or ACT payload types i.e the payload must have ROLE or ACT as entry point class. |
CTB_MTK_INTR_XSD_BUILD_FAILED |
INTERACTION SCHEMA validation failed. INTERACTION SCHEMA path: |
This error occurs when the uploaded xsds are incorrect or which have the datatypes or vocabulary values which are not supported in HDR. Please check that xsds generated by schema generator tool are correct and recheck the datatypes and vocabulary values used in RMIM (those have to be supported in HDR). Schema validation failure for interaction schema. |
CTB_MTK_MSG_PARSING_FAILED |
XML message parsing failed. CAUSE: |
This is a program error where MTK is not able to parse the test message to persist it. |
CTB_MTK_TRG_NOT_FOUND |
TRIGGER CODE |
This is a program error where the triggerCode generated in test message is an invalid concept. |
CTB_MTK_RIM_ASSOCIATION_NT_FND |
RIM ASSOCIATION not found in METADATA for ELEMENT name: |
MTK throws this error when it is unable to find the RIM association metadata for a RIM class from the database. As the metadata is generated from MIF file. Please check the MIF file is correct. The MIF file name can be found out from the complex type name given in the error message. |
CTB_MTK_PARNT_CMPLX_TYP_NT_FND |
The parent COMPLEX TYPE for the ELEMENT ' |
MTK throws this error when it is not able to find parent complex type for an element from MIF metadata. Please check the MIF file is correct. The MIF file name can be found out from the complex type name given in the error message. |
CTB_MTK_CODING_SCHEME_NT_FOUND |
Unable to get coding scheme, for CODE: |
This is a Program error where MTK is not able to find the code and code system name present in the test message from ETS. |
CTB_MTK_PAYLOAD_INFO_NT_FOUND |
Unable to parse PAYLOAD MIF file. PAYLOAD MIF file does not contain PAYLOAD ELEMENT, COMPLEX TYPE information. |
This is a program error which occurs due to failure in parsing of payload mif file. |
CTB_MTK_CMPLX_TYPE_NT_FOUND |
XSD COMPEX TYPE object for the COMPLEX TYPE name |
This is a program error. This error occurs when MTK does not find a complex type in the xsd. |
CTB_MTK_INCORRECT_FOCAL_CLASS |
The PAYLOAD XSD has unsupported focal CLASS. It should be either role or act. |
CTB_MTK_FILE_READ_FAILED |
Unable to read file |
This is a program error when MTK is unable to read a file from disk. |
CTB_MTK_FILE_WRITE_FAILED |
Unable to write into the FILE: |
This is a program error when MTK is unable to write a file to disk. |
CTB_MTK_METDATA_NOT_FOUND |
Unable to find METADATA for COMPLEX TYPE |
MTK throws this error when its not able to find metadata for a complex type. Please check the MIF file is correct. The MIF file name can be found out from the complex type name given in the error message. |
CTB_MTK_CLASS_CODE_NT_FOUND |
Unable to find CLASS CODE value for COMPLEX TYPE |
This is program error where MTK is not able to find a value for class Code attribute for particular xsd complex type. The error occurs when MTK is trying to generate the test message. |
CTB_MTK_PAYLOAD_NOT_FOUND |
Unable to find PAYLOAD in INTERACTION SCHEMA. |
This is a program error, When MTK tries to find the payload complex type from interaction schema to generate the test instance, it does not find that and throws this error. |
CTB_MTK_INCORRECT_INSTANCE |
Test message generation failed for INTERACTION SCHEMA |
This is a program error, This error occurs when MTK generates and incorrect test message and the schema validation for the message fails. |
CTB_MTK_CODED_ATTR_NOT_CREATED |
Unable to create XML fragment for CODED attribute for ELEMENT |
This is a program error. This error occurs when MTK is unable to fetch ETS data for coded attributes to generate the test instance. |
CTB_MTK_NOT_ENOUGH_VAL |
Concept list for CODEd attribute has less than two values for CONCEPT LIST |
If a concept list for a coded attribute has less than 2 concepts then this error is thrown . Please insert minimum of 2 concepts in all the extensible concept list. |
CTB_MTK_II_FRAGMNT_NT_CREATED |
This is a program error. This error occurs when MTK is not able to create id attribute data to generate a test instance. |
CTB_MTK_XML_FRAGMENT_NT_FOUND |
XML fragment is not seeded for data type |
When MTK does not find a xml fragment for a datatype to generate a test message, this error is thrown. Please verify the only HDR supported datatypes are used in the RMIM. |
CTB_MTK_ELMT_METADATA_NOTFOUND |
Metadata not found for an element name |
MTK throws this error when its not able to find metadata for a complex type. Please check the MIF file is correct or not. The MIF file name can be found out from the complex type name given in the error message. |
CTB_MTK_MSG_NT_PERSISTED |
IMP persistence failed. Acknowledgement message is |
When MTK tries to persist the message through IMP and it fails in persistence, this error is thrown. Please fix the error shown in acknowledgement message and rerun the test case. |
CTB_MTK_ATTR_VAL_NT_FOUND |
Unable to generate test INSTANCE . No default value found in XSD for ATTRIBUTE |
This is a program error. When MTK is not able to find a value for a structural attribute value from xsd or mif this error is thrown . |
CTB_MTK_INVALID_ACTRELATION |
Validation of input SCHEMA failed. ACTRELATIONSHIP COMPLEX TYPE |
This error occurs when MTK finds the an act relationship in xsd does not have a target act . Please fix the RMIM and XSD to have a target act for the corresponding act relationship. |
CTB_MTK_XSD_LOAD_FAILED |
Loading of Schema |
This error is thrown by MTK when the validation of uploaded xsd is failed . Please check the input xsds are correct. |
CTB_MTK_INVALID_OB_PRTCPN |
Validation of input SCHEMA failed. OUTBOUND PARTICIPATION COMPLEX TYPE |
This error occurs when MTK finds the a participation in xsd does not have a participant role . Please fix the RMIM and XSD to have a participant role for the corresponding participation. |
CTB_MTK_INVALID_IB_PRTCPN |
Validation of input SCHEMA failed. INBOUND PARTICIPATION COMPLEX TYPE |
This error occurs when MTK finds the an inbound participation in xsd does not have target act . Please fix the RMIM and XSD to have a target act for the corresponding participation. |
CTB_MTK_XSD_MIF_ELMT_MISMATCH |
Input SCHEMA and MIF files does not match. Element |
This error occurs when there is a mismatch between MIF and XSD file of the same artifact i.e an element found XSD file is missing from the MIF file. |
CTB_MTK_XSDMIF_CMPXTY_MISMATCH |
Input SCHEMA and MIF files does not match. SCHEMA COMPLEX TYPE |
This error occurs when there is a mismatch between MIF and XSD file of the same artifact, that is, a complex type found XSD file is missing from the MIF file. |
CTB_MTK_MS_SCM_VALIDATN_FAIL |
Message generated by OMP failed to validate against the schema. CAUSE: |
This is a program error. When MTK generates the persisted test message using OMP, the generated message fails schema validation and this error is thrown . Please contact your system administrator. |
CTB_MTK_COREMIF_PARSE_FAILED |
Unable to merge the existing CMETINFO.COREMIF with the one provided as input, because parsing of |
For merging the CMETINFO.COREMIF file new uploaded CMETINFO.COREMIF has to be parsed, if the CMETINFO.COREMIF is not a valid xml file then MTK throws this error. Please fix CMETINFO.COREMIF and upload again. |
CTB_MTK_NO_DEFAULT_CONCEPT |
CONCEPT LIST |
MTK throws this error when the default coding scheme has no valid concepts . Please ensure that all coding schemes have default version and should have at least one valid concept and concept list. These should have concepts from default coding schemes. |
CTB_MTK_ACTIVE_STATUSCD_NTFND |
Test message generation failed. STATUS CODE CONCEPT LIST |
MTK throws an error while generating a test instance,when it does not find an "ACTIVE" statusCode in the system conceptlist . Please ensure that ACTIVE concept is available in the concept list. |
CTB_MTK_MANDT_INPUT_MISSING |
The input parameter |
MTK throws this error when any mandatory input parameter is not passed by the user. |
CTB_MS_CMET_INFO_NOT_FOUND |
Unable to extract METADATA. CMET info file |
MTK throws this error from metadataservice when metadataservice is not able to find the CMETINFO.COREMIF file. Please check the CMETINFO.CORE MIF file is available on the server. |
CTB_MS_CMET_TYPE_NOT_FOUND |
Unable to extract METADATA. CMET reference |
MTK throws this error from metadataservice when metadataservice is not able to find the an entry of cmet in CMETINFO.COREMIF file. Please check the corresponding CMET entry is present in CMETINFO.COREMIF file. |
CTB_MS_MIFFILE_NOT_FOUND |
Unable to extract METADATA. MIF file |
MTK throws this error from metadataservice when metadataservice is not able to find the MIF file to load the metadata. Please check the corresponding MIF file is available on the server. |
CTB_MS_MIF_PARSING_FAILED |
Unable to extract METADATA. Unable to parse MIF file |
MTK throws this error from metadataservice when metadataservice is not able to parse a MIF file. Please check all MIF files are valid xmls. |
CTB_MS_CMETINFO_PARSING_FAILED |
Unable to extract METADATA. Unable to parse CMET info file |
MTK throws this error from metadataservice when metadataservice is not able to parse CMETINFO.COREMIF. Please check CMETINFO.COREMIF file is valid xmls. |
CTB_MS_INTR_SCHEMA_NOT_FOUND |
Unable to extract METADATA. INTERACTION SCHEMA file [ |
MTK throws this error from metadataservice when metadataservice is not able to find interaction schema on the server. |
CTB_MS_SCHEMA_PARSING_FAILED |
Unable to extract METADATA. Unable to parse INTERACTION SCHEMA |
MTK throws this error from metadataservice when metadataservice is not able to parse interaction schema on the server. Please contact your system administrator. |
CTB_MS_MIF_DIR_NOT_FOUND |
Unable to extract METADATA. MIF directory |
MTK throws this error from metadataservice when metadataservice is not able to find the directory for MIF files on the server. |
CTB_MS_WRAPPER_METADT_NOTFOUND |
Unable to load metadata for an INTERACTION SCHEMA |
MTK throws this error from metadataservice when metadataservice is not able to find metadata for the parent complex type element of the payload element in the database. |
CTB_MTK_STATUS_FILE_NT_FOUND |
The STATUS file ' |
MTK throws this error when it tries to download the status file from TEST_ID folder but does not find the folder with that TEST_ID name on the server . Please pass the correct TEST_ID name. |
CTB_MTK_TEST_ID_DIR_NOT_FND |
The TEST ID directory |
MTK throws this error when the Test ID folder is not found in the server. |
CTB_MTK_CMET_ID_CONFLICT |
Unable to merge existing CMETINFO.COREMIF with user provided CMETINFO.COREMIF. CMET name |
This error occurs when user try to upload a CMETINFO.COREMIF file which has an entry with same cmet name as that of the one which is already uploaded but the corresponding CMET IDs for the new one and existing one are different .So if the new file is merged with the existing file , then there will be 2 entries of the same CMET name with a different CMET ID. This is incorrect. Please upload unique CMET names at all times and not applied to other CMET IDs. |
CTB_MTK_CMET_NAME_CONFLICT |
Unable to merge existing CMETINFO.COREMIF with user provided CMETINFO.COREMIF. CMET id |
This error occurs when user try to upload a CMETINFO.COREMIF file which has an entry with same CMET ID as that of the one which is already uploaded. These have different CMET names .Therefore if the new file is merged with the existing file, then there will be two entries of the same CMET ID with different CMET names. To avoid this error please upload unique CMET IDs which are not already used with other CMET names. |
CTB_MTK_DUPLICATE_INTR_ID |
The INTERACTION detail for the INTERACTION ID |
When MTK tries to create a record for interaction ID in the database but the same interaction ID is already present then this error is thrown . Please use a different interaction ID which is not already seeded. |
CTB_MTK_UNSUPPORTED_IP_PARAMS |
Unable to create Composite Message Schema. The input parameter |
MTK throws this error when any input parameter is passed incorrectly; for example if a transmission wrapper ID passed by the user does not match with the transmission wrapper ID which HDR supports MTK throws this error. Please pass the correct input values. |
CTB_MTK_PAYLOAD_ID_NOT_EXISTS |
Unable to create INTERACTION SCHEMA PAYLOAD ID does not exist for the given INTERACTION ID: |
MTK throws this error when it does not find payload xsd on the server to create an interaction schema for it. Please upload the payload xsd first and then create the interaction schemas for it. |
CTB_MTK_PAYLOAD_XSD_NT_FOUND |
Unable to generate INTERACTION SCHEMA because Message Type XSD |
This error occurs when MTK does not find payload xsd on server with name given by the user . Please pass the correct payload ID as input. |
CTB_MTK_SCHEMA_IN_USE |
Unable to delete the SCHEMA |
The error occurs when a schema is tried to be deleted, is referred by a payload present on the server. To delete the schema please delete the referring payload first. |
CTB_MTK_HTB_ARTIFACT_FOUND |
Unable to delete ARTIFACTS. Customer cannot delete HDR specific ARTIFACT |
MTK throws this error when user tries to delete Oracle artifacts . You are not supposed to delete Oracle artifacts. |
CTB_MTK_INTR_SCHEMA_REF |
Can not delete PAYLOAD SCHEMA |
MTK throws this error when you tries to delete a payload and that payload has a interaction ID configured in the table. Please delete the interaction IDs for the payload and then delete the payload. |
CTB_MTK_XSD_NOT_EXISTS |
Unable to remove XSD |
This error occurs when an xsd is tried to be deleted which is not present on the server. In this case the xsd file name might be incorrectly passed. Please pass the correct xsd file name. |
CTB_MTK_PAYLOAD_FOUND |
Invalid input data because input contains a SCHEMA of a PAYLOAD. LOADSCHEMA API accepts SCHEMAS of CMETS only. Instead use API LOADCUSTOMMESSAGETYPETOPRODUCTIONSERVER. |
MTK throws this error when the uploaded schema is of type PAYLOAD . Only CMETS are allowed to upload using this API. Please upload only CMETS. |
CTB_MTK_INTR_DETAIL_NT_FND |
INTERACTION detail for INTERACTION ID |
When MTK tries to delete an interaction schema on the server ,and if it does not find a record for the corresponding interaction ID in the interactions table, it throws this error . Please ensure that interaction ID record is available in the interactions table before deleting it. |
CTB_MTK_INTR_RECV_CONFIG_EXIST |
Can not delete INTERACTION SCHEMA for INTERACTION ID |
When MTK tries to delete the interaction schema and for that interaction ID receivers are already configured then MTK cannot delete the interaction schema and throws this error. Please ensure that no receivers are configured for the interaction schema which is to be deleted. |
CTB_MTK_INTR_SENDER_CONF_EXIST |
When MTK tries to delete the interaction schema and for that interaction ID senders are already configured then MTK cannot delete the interaction schema and throws this error. Please ensure that no senders are configured for the interaction schema which is to be deleted. |
