Changing passwords
To change passwords for existing users:
- Use the PutProvisioningData operation.
To change passwords for existing users and return an identifier set for each user:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <USER> elements with existing USERNAME values and updated PASSWORD field values.
- Passwords specified with the API are subject to password policies defined in the InForm configuration (for example, at least one numerical character is required in the password). The USERNAME value is case-sensitive and must match exactly as described in Updating users.
