Resetting passwords
To enable or modify the password reset option for existing users:
- Use the PutProvisioningData operation.
To enable or modify the password reset option for existing users, and return an identifier set for each user:
- Use the PutProvisioningDataAndGetIdentifierSets operation.
Note: Use PutProvisioningDataAndGetIdentiferSets if the returned identifier sets are used within the client. The operation is significantly slower than PutProvisioningData.
Usage—for both operations:
- Specify one or more MedML <USER> elements using existing USERNAME values and desired USERMUSTRESETPASSWORD values.
- The USERNAME value is case-sensitive and must match exactly as described in Updating users.
