Assigning or updating a user password
After a user is created, the Change Password button is available on the User page, and you can assign the user an initial password. After the user logs on for the first time, he or she is required to change this initial password. To assign or update a user’s password:
- In the Trial Objects window, click the Admin icon.
- If the user’s status, as shown in the Status column, is Active, change the status to Inactive:
- Select the user whose password you want to create or update by clicking the check box in the X column.
- Click the Deactivate button.
- Clear the confirmation message that appears by clicking OK.
- Click the name of the user.
- Click the Create Password button (for a new user) or Change Password button (for an existing user).
The Password page appears.
- Enter a password for the user in the New password box.
- Re-enter the password for confirmation in the Confirm new password box.
- Click Submit.
