Conforming to password standards
When you set trial configuration options, as described in Defining system configuration settings, you specify the following options pertaining to password standards:
- Minimum password length.
- Number of failed logon attempts before the user’s password is inactivated.
- Requirement of at least one numerical character.
- Requirement of at least one uppercase character.
- Requirement of at least one nonalphanumeric character.
- Permission to reuse a password.
When you create a new password or modify an existing password, make sure that the new password you assign conforms to the standards that have been set for your trial.
Note: You cannot use a left angle bracket (<) or ampersand (&) in user passwords.
