Specifying unique key combinations
To specify that the InForm application should evaluate a group of unique keys in combination:
- Identify a set of key items that are unique keys, as described in Specifying separate unique keys.
- Set the value of the Unique Key property of the repeating form or itemset to True:
- In the Form window, select the form or itemset node, as appropriate.
- In the Properties window, select True as the value of the Unique Key property.
