Creating a CDD mapping definition table
To create a CDD mapping table definition:
- In the Data Mappings window, right-click the CDD mapping RefName, and select New Table.
A new table line is added to the Data Mappings node in the Data Mappings window.
- In the Data Mappings window, select the table name.
- Edit the CDD mapping table property values in the Properties window.
The following table describes the properties of a CDD mapping table definition:
Property |
Description |
Name |
Name of the data mapping target table. When you update this name, the new name is reflected in the Data Mappings window. This name can have a maximum of 30 characters. REQUIRED.. |
Key Type |
For the following key types, this specifies the composition of the primary key columns of the target table. Each time a component of the primary key changes from the previous primary key submitted, the InForm application inserts a new row in the target table. Primary keys consist of the following DBUIDs and indexes:
Pivot Column |
Identifies the column to use as the pivot column, if the key type is Pivot Form, Pivot Patient, Pivot Section, or Pivot Visit. |
Note: A table that has mappings for controls within an itemset cannot have any of the pivot key types. Additionally, a pivot column must be the first column in a data mapping table. When you select a pivot column, if it is not the first column, the InForm Architect application prompts you to reorder the column. If you do not choose to reorder the column to the first position in the table, the InForm Architect application does not make the column the pivot column.
