Creating a CDD mapping definition table column
Creating a CDD mapping definition table column with the InForm Architect application has two parts:
- Defining a column in a CDD mapping table.
- Identifying the form controls that are mapped to the column.
You can do these activities as separate steps, or you can create both the column and the control mapping in a single step.
