Creating only a column definition
To create a column definition that does not include a control mapping:
- In the Data Mappings window, right-click the name of the table in which you want to create a new column.
- From the pop-up menu, choose New Column Definition.
The InForm Architect application adds a new column line to the table node in the Data Mappings window, and you can define its properties as described in Defining CDD mapping table column properties.
