Creating a column definition and mapping a control
To create a table column definition and control mapping in a single step, you can do either of the following:
- In the CDD Mappings window, use the New Column pop-up menu command for the table in which you want to create the column and control definition.
- In the Form window, you can either use the Add Data Mapping pop-up menu command to map a control, or you can drag the control from the Form window onto the Data Mappings window.
